Paint or Powdercoat? - Defender Source
Old June 15th, 2011, 12:00 PM
floyd650's Avatar
floyd650
Alex Lapidus
1994 D90 ST #1716
While my 90's getting a 4.6 put in, I decided to pull all the crusty bits off and re-paint/powdercoat them. I'm going to do the winch bumper, rock sliders, rear tire carrier, and third brake light bar. What do people recommend as the most durable finish? I live in Oregon where it rains everyday but the roads are never salted.
Old June 15th, 2011, 12:10 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Everyone probably has their own view on which is better, but I think it's safe to say that the more important point is how good the prep and application is done.
Old June 15th, 2011, 12:21 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Paint can be touched up, powdercoat requires blast and finish. If you are going to use the rock sliders I would go with paint. Also over time Powdercoat will fade faster due to UV rays.
Old June 20th, 2011, 05:50 PM
floyd650's Avatar
floyd650
Alex Lapidus
1994 D90 ST #1716
I decided to powder coat everything. When I dropped my stuff off I had to chose a finish and I went with what is called "P009-BK180 Black Ultra-Smooth 90% Gloss" from Cardinal Paint products (http://www.cardinalpaint.com/product...l.php?ccsid=32). It is their 90% gloss black. I want everything to look new and OEM, but I know the cage is more of a satin black. Is it going to look wierd if the bumper, sliders, tire carrier and third brake light are glossier than the cage?
Old June 20th, 2011, 06:59 PM
CDeWan
Clay DeWan
5.3L beastie
No one will notice as these items are usually to far away from the cage. If it was piece against piece, most likely. Why don't you get the front A cage powder coated as well. It is easy to take off 10 bolts 4 pieces. I went that route. O....and going along with Thomas stick some wax for UV protection though since your in Portland I am not sure how much sun that truck will see unless you send it off to a tanning booth
Old June 20th, 2011, 07:25 PM
floyd650's Avatar
floyd650
Alex Lapidus
1994 D90 ST #1716
Seriously. I'm originally from CA, and have been up here for the last 12 years. This is the worst year I've seen for rain. But that's exactly why I wanted a soft top: when the sun DOES come out, I want every last photon of UV light I can absorb.
Old March 25th, 2014, 08:24 PM
Hache
Henry Lambert
1983 Ex-MOD 90 2.5N/A
Did you end up powder coating? what place did you use? I'm looking to get my rims powder coated and have been quoted both $40 per rim and $100 per rim in PDX.
Old March 25th, 2014, 08:47 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I would powdercoat if it's on the underside (away from direct sunlight) OR you are willing to have it re-done every 10 years.
Salt is coming, btw...
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old March 25th, 2014, 09:01 PM
Hache
Henry Lambert
Thanks Jeff I'll check out Les Schwab.
I just read about the salt in the Oregonian. Perfect timing for my steel framed Land Rover's arrival.
paint
touch up paint januconn92 Defender Technical Discussions 3 January 30th, 2007 10:01 AM
Paint Color/ Paint Code little black duck Defender Technical Discussions 3 March 16th, 2005 05:30 PM
Wheelwell paint rustydefender Defender Technical Discussions 6 February 9th, 2005 02:08 PM
Paint Code? Trigger Defender Technical Discussions 4 June 17th, 2004 01:45 PM
Paint a fiberglass hardtop? roverboy Defender Technical Discussions 5 December 12th, 2003 09:52 AM
