Paint Code? - Defender Source
Old June 17th, 2004, 01:31 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Paint Code?
Ok, I've looked all over the Net and can't find it. The paint shop can't find it through their sources either. My baby is stranded at the shop all masked and ready to paint for lack of a pint code. I need the paint code for '94 Conniston Green.
Anyone?
Old June 17th, 2004, 01:33 PM
http://www.defendersource.com/faq/Bo...oat.html#Codes
Coniston Green LRC570/HYE
Is that it?
Old June 17th, 2004, 01:37 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
www.paintscratch.com will have it. Call them. I provided them with the VIn and they correctly supplied me with Alpine White base and the proper clear coat. They also do larger orders even gallons. The paint is very good and is a perfect match.
There also should be something like this:
http://www.paintscratch.com/colALL.htm
which shows the correct color for the truck. The shop should be able to properly decifer the codes and order the paint of your choice, such as OEM or PPG for instance.
EwS
Old June 17th, 2004, 01:40 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
You know, I searched d-90.com but that page didn't come up in the search. I found a guy at the dealer who manged to track it down. That's the same one he gave me.
Thanks.
P.S. Dang it. I just reran a search of d-90.com and that page showed up. Now I look stupid. I _know_ it didn't show the first time.
Old June 17th, 2004, 01:45 PM
LOL, thats OK Tony I belive you.
paint
NATO Green Paint code TDI Guy Defender Technical Discussions 34 December 21st, 2016 05:30 PM
Buluga Black Paint Code CDeWan Defender Technical Discussions 2 November 18th, 2009 12:21 PM
Paint code Nobrega Defender Technical Discussions 18 April 22nd, 2007 10:55 AM
Paint code for Monza Red shawnpalmer Defender Technical Discussions 2 February 16th, 2007 10:35 AM
Paint Color/ Paint Code little black duck Defender Technical Discussions 3 March 16th, 2005 05:30 PM
