Paint code - Defender Source
Old May 12th, 2004, 01:29 AM
Nobrega
Andrew Nobrega
'94 Defender 90
Paint code
Hey, does anyone know where the paint code is on the D90 ST, I need to do some cosmetic work and need the code for Alpine white, and the black used on the bumpers. Thanks - Andrew
Old May 12th, 2004, 06:41 AM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
Alpine White
I think the code for Alpine White is LRC456/NUC-Just ordered some Coniston Green so I have the paint codes. As far as the black I just used a flat black paint.
Darrin
Old May 12th, 2004, 11:09 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I also used a generic black on my bumper. Semi-gloss though.
EwS
Old February 21st, 2007, 06:24 PM
GYM's Avatar
GYM
Gary
97 SW
Hello all:
Does anyone know the LR factory paint code/description for the semi-gloss black paint used on the bumpers/cage? I've searched through the FAQ here, ECR website, Paintscratch, Google, et al. and can't seem to locate it.
I know a generic semi gloss would work fine, but feel compelled to use the factory shade...
Many Thanks.
Old February 21st, 2007, 06:26 PM
Chaucer
Will
93 110 | 97 90
I don't know the code, but it's usually called "satin black".
Old February 21st, 2007, 07:30 PM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
90991 is PPG Alpine White paint code. Bought some a few weeks back.
Old April 3rd, 2007, 08:32 AM
Norton's Avatar
Norton
Max Essery
'95 D90 ST
Looking to do some touch up and paint my hinges. Anyone know of a close match for alpine white in a spray can? Say from napa, autozone etc. Thanks.
Old April 3rd, 2007, 12:11 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
You can still order Alpine White in a spray can for touchup from the dealer! I ordered a couple cans about 6 months ago!
Old April 3rd, 2007, 01:31 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Is it base coat? Can you clear coat it after or is it single stage?
Neil
Robert Deniro
Old April 3rd, 2007, 01:39 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Single Stage I believe. I haven't used it yet, in fact I haven't even opened the boxes it came in yet.
Old April 3rd, 2007, 02:09 PM
mattarm's Avatar
mattarm
Matt
1993 D110
One of the local car parts shop here mixed the color based on some sort of color codes from a database. Color was Alpine white, problem was after my 110 spent 13 years outdoors, it was a little too white to match. When I do my hinges, I plan to have a shop color match rather than go with the "original" color.
Old April 4th, 2007, 01:59 PM
Norton's Avatar
Norton
Max Essery
'95 D90 ST
Called two dealers today, one in RI and one in MA, both said the spray cans are no longer available. Any other ideas for sources? If not I guess I'll try an auto body shop. So much for hoping for an easy way out.
Old April 4th, 2007, 02:11 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I got some LR shake-n-spray from Rovers North with a set of replacement hinges. Then later a custom mixed (based on vehicle lookup) from carquest (www.carquest.com). The product from CarQuest was a far better quality, although not inexpensive either.
Old April 4th, 2007, 02:18 PM
Norton's Avatar
Norton
Max Essery
'95 D90 ST
I also called RN, they no longer stock the spray cans. Thanks for the other lead.
Old April 4th, 2007, 04:31 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
That seems strange...I just ordered them through the dealer where I work only a couple months ago. Sorry.
Old April 4th, 2007, 05:53 PM
Spectre
Stephen
'76 SIII Lightweight
Whats the proper procedure for using the Alpine White spray can? I have a place with a little rust on this truck Im getting, do u need to strip, prime and paint, or just strip and paint?
Old April 4th, 2007, 06:37 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Have you guys tried PaintScratch?
http://www.paintscratch.com
Old April 5th, 2007, 04:24 AM
Captain Spalding's Avatar
Captain Spalding
Captain Spalding
More and more auto paint suppliers are offering color matched paint in spray cans. My local shop asks $25/can. Not bad when you consider that it's a custom color.
Old April 22nd, 2007, 10:55 AM
bomilcar's Avatar
bomilcar
Stephen Miller
73 Series III Orig Owner
To clear coat or not?
Ordered new style door hinges for my 94 ST from RDS. Got the primer, base, and clear coat kit from PaintScratch.com. Two coats of primer; 6 hours appart. 3 coats of base Alpine White; 3 hours appart. Now the question: to clear coat or not?
From reading the various posts it sounds like the 94s sis not come with any clear coat in Alpine White. Will the clear coat protect better than with it?
Should I work over the base paint with the compount that is in the kit if I decide not to clear coat. They tell you to compound the clear coat but make no mention of the base coat.
Any input would be greatly appreciated,
Steve
73 Series III (Original Owner)
94 D-90
2011 LR4
"anything that can go wrong has"
paint
NATO Green Paint code TDI Guy Defender Technical Discussions 34 December 21st, 2016 05:30 PM
Buluga Black Paint Code CDeWan Defender Technical Discussions 2 November 18th, 2009 12:21 PM
Paint code for Monza Red shawnpalmer Defender Technical Discussions 2 February 16th, 2007 10:35 AM
Paint Color/ Paint Code little black duck Defender Technical Discussions 3 March 16th, 2005 05:30 PM
Paint Code? Trigger Defender Technical Discussions 4 June 17th, 2004 01:45 PM
