P38 Overheating - Page 2 - Defender Source
Old February 23rd, 2013, 03:52 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
yea forgot to mention your probably going to have to replace all the exhaust down pipe studs which is very common
No Mall crawler here
Old February 25th, 2013, 10:27 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Progress. Pulling heads tomorrow. Fingers crossed I don't find slipped liner. So far so good.
ID:	67015   Click image for larger version
~ Semper Fidelis ~
Old February 26th, 2013, 12:13 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
unfortunately you won't be able to see it ....your saving grace is that the gasket blew out ..
Old February 26th, 2013, 06:27 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Glad to see you are making progress!
Semper Fi!
Old February 26th, 2013, 10:09 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Make sure you get those heads checked out for straightness and valve sealing in the combustion chamber.....
Old February 26th, 2013, 12:16 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
doing that by yourself
Old February 26th, 2013, 12:23 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Having heads done at shop. Doing the rest of the work myself.
~ Semper Fidelis ~
Old February 26th, 2013, 12:39 PM
Wolf Fabrication
Sterling Archer
'08 D3
Wait, you should be able to see a slipped liner, its the cracked one that's hard to see.
Semper Fi!
Old February 26th, 2013, 12:59 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
A slipped liner can be seen in some cases and felt by running a point over cylinder edge. but crack are another story.
Old February 26th, 2013, 02:40 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
let's just say after 20+ yrs and thousands of heads and motors Iíve done. Iíve physically seen 2 liners slipped in the bore and they were just touching the crank .noted by a lower end tap like a bad lifter the other signs of slipped liners were detected from the bottom with traces of coolant between the bore and sleave ....in any case just trying to help and guide you in the right direction ....."Fix it right the first time"
Next Tip:..clean the rocker shafts/arms and check the rocker arm tip cups if they rotate or move replace them now or she'll tap
Old February 26th, 2013, 03:17 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
let's just say after 20+ yrs and thousands of heads and motors I’ve done. I’ve physically seen 2 liners slipped in the bore and they were just touching the crank .noted by a lower end tap like a bad lifter the other signs of slipped liners were detected from the bottom with traces of coolant between the bore and sleave ....in any case just trying to help and guide you in the right direction ....."Fix it right the first time"
Explain more "tip cups"
~ Semper Fidelis ~
Old February 26th, 2013, 03:57 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
the underside of the rocker arm which is aluminum there is a steel cup steaked into the arm tip where the pushrod rides on it over time they get loose .. use a pick and see if you can rotate the steel cup if it moves you should replace the arm .. crappy desgin had a brand new rocker assembly start making noise after the first oil change ... stick with rotella and change every 3k
Old February 27th, 2013, 08:58 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Pulled drivers side head. 3 of the rear head bolts were VERY loose, and I could see where the head gasket failed. Good news is I can't see any visual signs of slipped liner. At first glance I thought all the liners had slipped but then I realized the head gasket was still on the block Ha. All cylinders looked equally dirty, no dramatic variations.
I will work on other head tomorrow. I broke 2 sockets on the first head bolt late in the evening so I called it a night. Torque on the head bolts are all over the place. Glad I will be going with studs.
Old February 28th, 2013, 10:12 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Heads off to machine shop. All going well. Waiting on arp studs. Should have running by next week or two.
ID:	67167   Click image for larger version
~ Semper Fidelis ~
Old March 1st, 2013, 06:25 AM
Wolf Fabrication
Sterling Archer
'08 D3
Fun stuff
Semper Fi!
Old March 1st, 2013, 07:13 AM
The Dro
Dro
1988 Ninety
It's probably a LONG time since you had a Rover... You can eat off that garage floor.
Old March 6th, 2013, 01:46 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Done. Everything Seems to be good. I will take out once I dig cars out of driveway ( snow).
ID:	67516   Click image for larger version
~ Semper Fidelis ~
Old March 6th, 2013, 02:15 PM
awesome!!
Old March 6th, 2013, 02:42 PM
Wolf Fabrication
Sterling Archer
'08 D3
Congrats Adam, hopefully it's fixed and we better see you at Wintergreen.
Semper Fi!
Old March 7th, 2013, 07:45 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Put about 15 miles on it today. No overheating. I couldn't make It past my street before, pretty sure problem solved. Now to heater core oring.
~ Semper Fidelis ~
overheating
Baffling Overheating Saga Trevor Tarr Defender Technical Discussions 51 May 20th, 2010 10:41 AM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Overheating Question PT94D90 Defender Technical Discussions 10 July 12th, 2005 04:39 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
overheating issue--viscous fan Davis Defender Technical Discussions 5 August 4th, 2004 12:11 PM
