P38 air suspension reservior inlet? - Defender Source
Old October 24th, 2015, 12:26 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Does anyone know off hand what size the inlet fitting on a P38 air tank is? It is not a 1/2" npt so I am guessing it's AN?
It seems way too nice a little tank not to repurpose for on board air!
Old October 24th, 2015, 12:30 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Quite possibly BSPT as I do not believe LR uses NPT anywhere on the truck.
Old October 24th, 2015, 02:42 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
The label on the tank warns that it is a sealed dry air system with an inline air dryer so I thought it might use AN cooling system fittings.
Either AN or BSPT I think I am just going to weld an NPT over the existing port.
Old October 25th, 2015, 12:59 PM
carlosz's Avatar
carlosz
Carlos
on my classic I removed one of the plugs at end of tank, it is npt. then used a reducer in order to fit a 3/8 quick release line from an arb compressor.
I left the factory line intact...
Old November 1st, 2015, 03:53 PM
On the classic tank from a 93 LWB that I have, the threads are 10mm 1.0 or damn close to it if not that.
Does anyone know what size alan key the bottom drain plug is?
Originally Posted by pendy
I'm here for the D's
Old November 1st, 2015, 04:30 PM
carlosz's Avatar
carlosz
Carlos
C, I believe it is 8 mm allen, don't buy it I have a heavy duty kit...
let me know when you want me to swing by with it...
Old November 1st, 2015, 05:35 PM
Naah, I don't need you to go out of your way for this.
Are they measured across the flats? If so it's M12. The side on is 10mm across and I used a 3/8th on it.
Old November 1st, 2015, 07:48 PM
carlosz's Avatar
carlosz
Carlos
I have always measured by the drive yes across the flats, when I was an apprentice someone told me to find a bolt to place in there, then look for the drive matching that bolt head and there is my allen tool size ... now a days that formula is more confusing than helping.
I have the gamut from 3 or 4 mm to 17 mm and standard size.. torx and security bit drivers...
Fuel inlet size on side of tub MUDSUX Defender Technical Discussions 4 July 18th, 2010 09:21 PM
300tdi inlet manifold cabell Wanted 1 June 26th, 2008 06:46 AM
muffler inlet size kolvedic Defender Technical Discussions 1 February 10th, 2006 06:29 AM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
Radiator reservior overflow Neo Defender Technical Discussions 1 February 27th, 2004 11:51 PM
