P1414 and P1417 on 4.6 - Defender Source
Old September 22nd, 2014, 01:31 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Anyone had those codes before ?
According to what I've been reading
main suspect is SAI solenoid valve, then
SAI pump.
I can check SAI pump bypassing relay but
what about solenoid, is there a test for it, is
it serviceable ?
Cheers
- Charles Eames
Old September 22nd, 2014, 01:46 PM
The Dro
Dro
1988 Ninety
You have SAI faults and they are a bitch to figure them out.
Old September 22nd, 2014, 07:44 PM
What is the description for the two faults? Sorry, I don't feel like searching them. Check the vacuum lines that go to the SAI valves and pay particular attention to the connection at the reservoir.
Old September 22nd, 2014, 07:49 PM
the rover shop
shayne young
You can energize the blower motor and it should pump air.. The sai valves on each side can be tested with a vacuum pump, they should open with vacuum and hold vacuum.. Not serviceable but aren't too bad to replace just the valve itself..as jimmy said.. Make sure all the vacuum lines are on.. 2 on the vacuum reservoir.. One on the I take manifold , 2 on the vacuum valves and 2 on the switching valve behind the throttle body.. They get swelled up with contamination and sometimes fall off... We just wrap a small zip tie around them and it snugs them tight..
Old September 22nd, 2014, 08:07 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Low air flow bank 1 and low air flow bank 2
------ Follow up post added September 22nd, 2014 08:11 PM ------
I did that with the previous vacuum hose, this one is less than a year, but may it's time to do it to this one also.
- Charles Eames
Old September 22nd, 2014, 08:56 PM
the rover shop
shayne young
Sounds like you end a new air pump..
Old September 22nd, 2014, 11:26 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
My bet is on the solenoid for now, if it's the pump i'll try to rebuild it.
- Charles Eames
Old September 24th, 2014, 09:05 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
That was an easy one, broken vaccum line.
- Charles Eames
110 bench seats and belts source and install and roll cage ? klawler9 Defender Technical Discussions 3 December 28th, 2013 12:21 PM
B and C pillar and other stuff and stuff for trade bstraw Wanted 2 January 10th, 2007 12:11 PM
