P1193 Fault Code - Defender Source
Old July 14th, 2010, 11:10 AM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
P1193 Fault Code
Getting a "P1193 Manufacturer Control Fuel Air Metering" using an Cctron OBD II AutoScanner. Searched this one but only found the P1193 and a different type of fault. Tried clearing it but it comes back after a few starts. Truck has sat for a long time and I did not have any codes until I recharged the battery. Only thing not stock on the truck is the radio but I believe the factory amp is still hooked up(pertaining to one of Mike at ECR's old post from way back). Thanks in advance if you can help. Mike
Old July 14th, 2010, 04:23 PM
mpsteil
Michael Steil
Anybody?
Old July 14th, 2010, 09:21 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
it should be o2 sensors. I would replasce both banks
Old July 15th, 2010, 06:06 AM
The Dro
Dro
1988 Ninety
That code is: Oxygen Sensor Heater Circuit Open Downstream.
Any code that has a 1 after the P, instead of a 0 is a LR enhanced code.
EDIT: Here are LR specific codes: http://www.obd-codes.com/trouble_codes/landrover/
If you are REALLY bored... http://www.aa1car.com/library/o2sensor.htm
Old July 15th, 2010, 11:49 AM
mpsteil
Michael Steil
Cool, thanks PL and David. I was thrown off by my scan tool saying "P1193 Manufacturer Control Fuel Air Metering".
Old March 29th, 2017, 01:36 PM
rovermonkey
Sean Copp
Red 97 ST Defender
Argh. Replaced all for sensors and still getting P1193 error. One of the downstream connectors had some corrosion which I've vigorously cleaned. Any other ideas on what could be wrong?
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Fault Code "03" Doug Defender Technical Discussions 15 July 18th, 2005 10:38 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
Fault Code 45? Troys Defender Technical Discussions 2 October 20th, 2004 01:04 AM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
