P1193 Code Explanation - Defender Source
Old April 14th, 2014, 10:54 PM
Videoguy
Ron
1997 Defender 90 SW
My 97 D90 keeps throwing the 1193 code, "Oxygen Sensor Heater Circuit Open Downstream".
The schematic does not help much. Can anyone help me with a better explanation and what I should be looking for?
Old April 14th, 2014, 11:30 PM
A bad rear (post cat) o2 sensor or a break in the wire to the O2 sensor. If you are cheap you can swap the left to the right and see if the fault moves or stays on the same side to figure out if it is a wiring issue or a bad sensor.
P1193 Fault Code mpsteil Defender Technical Discussions 5 March 29th, 2017 01:36 PM
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Radio Code Help? ;) wicks Defender Technical Discussions 7 December 31st, 2009 07:59 AM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
