P1179 Fault Code - Defender Source
Old June 21st, 2007, 03:50 PM
nmc
Noel Corpus
1997 Defender 90 LE
P1179 Fault Code
My check engine light has been coming on recently and my code reader is me telling it's P1179 Fault (AMFR max negative value). I've done a search, but found nothing on possible causes for a AMFR (Air Mass Flow Rate) One week prior to the first check engine light coming on, I installed a Mantec Snorkel. Could this be a possible reason? Has anyone else experienced a P1179 fault? Any insight is appreciated.
Thanks.
Noel
Old June 21st, 2007, 11:55 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Noel, I got an 1179 a year of so ago and it was caused by a plugged fuel filter. pressure was ok but volume was low(happened after some good wheeling and it must of churned up some stuff in the tank)....injectors couldn't atomize the fuel properly...the engine runs lean because the ECU can't adjust for the low pressure, cats don't heat up properly, then the maf tries to richen the mixture, when it reaches the limit. it throws a the code.
toss a fram in there and give it try, could be fuel pump but try the filter first...also get some good contact cleaner(no residue) and clean the maf sensor in case you got some grime on the sensor
I use crc
http://www.crcindustries.com/auto/co...x?PN=05110&S=N
j
Old June 22nd, 2007, 10:59 AM
nmc
Noel Corpus
1997 Defender 90 LE
Jeff,
Thanks for the insight.
Noel
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Fault Code "03" Doug Defender Technical Discussions 15 July 18th, 2005 10:38 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
Fault Code 45? Troys Defender Technical Discussions 2 October 20th, 2004 01:04 AM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
