oversteer with locker - Defender Source
Old March 15th, 2007, 07:18 PM
andyrad
Andy Radlgruber
None.
I recently intalled a Detroit locker in the rear of my D90 and now when I am on the gas through a corner and then take my foot off the pedal while still in the turn, the front end grabs a bit and I get some oversteer. I know now to expect it but it's still kinda unnerving in case of an emergency maneuver. Has anyone with a rear Detroit also had this problem. I installed a True Trac in the front a week later and there was no improvement or change.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old March 15th, 2007, 07:28 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Are you absolutely sure you don't have a bad bushing on one of the control arms? I replace them yearly just because of the bad oversteering they cause. Might just be coincidence that you noticed it after the Detroit install....
My thoughts.
Doug W.
Old March 15th, 2007, 07:35 PM
andyrad
Andy Radlgruber
None.
RTE longtravel lift will be here in about a month. I'll change them then. Might be a coincidence like you said.
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
This is the way I believe it is happening.
The detroit wants to push you straight when locked, and it will lock up under load, so on the gas, and you aren't able to turn as well, get off the gas, the locker unlocks, becomes a diferential, and you can turn again.
I know I can't turn for poop if my rear ARB is locked.
I got your JEEP thing, now it hurts when I pee!!
Old March 15th, 2007, 08:19 PM
Tom Fitzgerald
Tom Fitzgerald
Detroit
Common behavior for a Detroit. Had one in the rear of a Toy PU once. It is as Tim says, once you lift off the throttle, the rear unlocks and unloads a good bit of bind and it's actually the rear coming around on you a bit more so than the front 'grabbing'.
It's a trait you can adapt to, but will remain unsettling, especially on an exit ramp in the rain.....my deductible alone made an ARB a wise upgrade at the time!
Tom
Old March 15th, 2007, 09:27 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
You have to either coast around a ramp or stay on the gas the whole way, common DT behavior as stated above.
Old March 15th, 2007, 10:39 PM
andyrad
Andy Radlgruber
None.
Thanks so much for the input. I read a thread on which locker has the best road manners and most people said ARB. I didn't want to fuss with air seals and lines and a pissy little compressor, not to mention having to turn it on "when you may need it". No offense to ARB but I didn't think it was for my kind of wheeling. However, nobody mentioned the oversteer factor in that thread in regards to ARB. I guess it's time to change my driving style a bit, depending on the vehicle of the day. I have always entered turns a little quicker and then let off the gas midway instead of hitting the brakes. Now I'll have to enter at the correct speed and accellerate through the turn, like you should do anyway.
Problem Solved
Old March 20th, 2007, 02:02 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
I have a Detroit in my 110 and I had one in my Discovery before that. I've never, to my knowledge, had any issue with oversteer. Understeer, sure, except it's not really the same as understeer in a car as it's the rear diff that's driving it rather than the centre of gravity.
I'm not disagreeing with anything anyone else has said, and I guss my experiences are different as I've only driven longer wheelbase vehicles with the Detroit for any distance.
The places you really notice the Detroit are in sand and snow. The vehicle mostly wants to track in a straight line a bit more. IMHO it makes it a bit less fun in sand, and it can cause it to crab sideways a bit in snow. I just went through all winter with my 110 though and I'm still happy it's in there.
- Andrew.
1986 110 CSW 200tdi (
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
Locker Question RickM Defender Technical Discussions 14 April 9th, 2006 12:41 PM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Locker - Front or Rear bd90 Defender Technical Discussions 6 January 14th, 2004 09:22 PM
ARB locker TwisteD90 Defender Technical Discussions 2 December 2nd, 2003 11:26 AM
