Overheating with thermal imaging - Defender Source
Old June 7th, 2011, 11:08 AM
Seanh
Sean Hanagan
94 D90 ST #910 Matilda
I have the dreaded overheat issue and decided to utilize some borrowed technology. My situation goes like this. Needle creeps close to red under load both at highway speeds and crawling. I have not experienced a boil over or steam. I have attempted to;
Top off coolant
Replace thermostat
Check fan clutch=ok
Take thermal images
My motor is a 94 3.9 with 184XXX
Here is the (#1) lower hose, (#2) upper hose and (#3) radiator top and (#4) bottom at normal needle position. Next set of images are from an overheat I created last night under highway load. Image (#5) is lower hose, (#6) is lower radiator through grill (#7) is hottest spot I could find on the motor just behind the lower hose. (#8) is the guage position from the overheat. The one image I lost was the upper hose which was 193 degrees. I was hoping someone could help determine if the radiator is the problem or should I look elsewhere?
Name:	lower normal.JPG
ID:	39439   Click image for larger version
Name:	upper normal.JPG
Name:	rad normal.JPG
ID:	39441   Click image for larger version
Name:	upper rad normal.JPG
ID:	39443   Click image for larger version
Name:	motor hot spot.JPG
ID:	39445   Click image for larger version
Old June 7th, 2011, 11:14 AM
Cool toy ... has the radiator ever been replaced / flushed??? I can't figure out from your pictures but if the bottom of the rad is cooler, potentially it is a bit blocked and reducing the flow.
I had over heating problems and after having the rad replaced and various other efforts it turned out to be the pressure cap on the expansion tank ... get a new one and that will ensure that the system pressurizes and the cooling is most effective.
Old June 7th, 2011, 11:31 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Temps under 200f shouldn't push the temp gauge into the red. The temps in the Flir pics don't look way out of line, and you say no boiling over. You might just need a new sender, or to provide a better ground for the gauge.
Tony
1984 110 "Smokey" (sold)
Old June 7th, 2011, 12:10 PM
Seanh
Sean Hanagan
Edited to show the temp gauge last night. I've seen it go just below the red.
Old June 7th, 2011, 01:33 PM
Do the hoses stay hard after you shut off the truck?
If so, I would bet on the rad. If not, find the pressure leak and fix it.
Old June 7th, 2011, 01:43 PM
Seanh
Sean Hanagan
I took it to a mechanic and he pressurized the system overnight and said it wasn't loosing pressure.
Old June 7th, 2011, 01:55 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Those temps don't seem high to me. I would check the sender's ground. Also check and see if the gauge moves up when you put on all the lights, ac. heater ect. Mine did this and it turned out to be a bad ground.
Old June 7th, 2011, 05:47 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
My gauge used to get to about the same point under the same conditions. I installed a Vdo gauge and sender and I have yet to see it go above 200 on the new gauge. I'm guessing it's the sender or gauge. Temps shown on the infrared don't look unreasonable.
I did install a dedicated ground for the new gauge, otherwise it wouldn't work. FYI if you go that route.
Old June 8th, 2011, 12:06 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Would have to agree. I would be looking for a ground circuit problem for the guage. The radiator needs to be rodded and cleaned if it is an original part as a matter of maintenence really. Good radiator shop can comment on the condition of the radiator when you take it in for a rodding and cleaning.
legend in my own mind
Old June 8th, 2011, 12:39 PM
Seanh
Sean Hanagan
Thanks all!
Old June 8th, 2011, 02:32 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
When you turn off the truck and immediately restart the engine does the temp gauge go back up toward hot? If the gauge goes back to the middle than I would suspect the gauge.
overheating
Baffling Overheating Saga Trevor Tarr Defender Technical Discussions 51 May 20th, 2010 10:41 AM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Overheating Question PT94D90 Defender Technical Discussions 10 July 12th, 2005 04:39 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Overheating fun... Trigger Defender Technical Discussions 10 May 16th, 2005 10:04 PM
