overheating w/ everything new - Page 2 - Defender Source
Old April 5th, 2006, 07:30 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Ah, found the compatiblity list. The fan switch in the thermostat neck of a 94/95 is the same as in a
75-84 Rabbit
80-83 Jetta
74-80 Dasher
two part numbers at NAPA, both should be under $20
Beck/Arnley 2010809 = 92C switch/197F
Beck/Arnley 2011545 = 82C switch/180F
Found it in the FAQ actually, along with the claim that the factory switch is 109C/228F. OUCH.
I used the 82C switch in mine, and it worked perfect. The fans came on just as the thermostat opened up. Then the switch went bad in the middle of the winter, ack. So I just jumpered it and ran the fans all the time, now that it's warming up, time to get a new switch.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 5th, 2006, 09:01 AM
Andrew Vick
Andrew Vick
95 D90
When you're good, you're good. Thank you very much.
Old April 5th, 2006, 09:13 AM
artm
Arthur Maravelis
97 SW
Can I assume that this is not good for a 97?
Old April 5th, 2006, 12:39 PM
Hans's Avatar
Hans
Hans Haase
Not sure about a 97 at all, I really never had a chance to play under the hood of one, so I don't even know if they have the same setup for the thermostat neck.
-Hans
My oil line fix
Old April 5th, 2006, 06:26 PM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
For what it's worth, on my 97, which was having overheating problems for about a year, I've added a switch to manually activate the a/c fan. I'm not sure what temperature it automatically triggers at, but this way I can get a little extra oomph of cooling when I need it.
Old April 6th, 2006, 02:44 PM
artm
Arthur Maravelis
97 SW
Manual says the condenser fan comes on at 225, read through the coolant temp sensor. Ther is no fan sensor in the radiator hose, so the ECU reads the sensor.
Looks like a new tap is required to fit a fan switch. Or use the hose from a 94/95? Are you guys sure these hoses have a separate fan switch? I would think the ECU would handle it as in the 97.
Old April 6th, 2006, 02:58 PM
They do, the 94s and 95s have the 14CUX computer that is not nearly as complex as the 97s ECU.
Old April 23rd, 2006, 08:42 AM
Andrew Vick
Andrew Vick
95 D90
Flow tested and rodded the radiator. All's good on steep inclines in 75 degree heat yesterday, second gear for miles at a time
overheating
Baffling Overheating Saga Trevor Tarr Defender Technical Discussions 51 May 20th, 2010 10:41 AM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Overheating Question PT94D90 Defender Technical Discussions 10 July 12th, 2005 04:39 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Overheating fun... Trigger Defender Technical Discussions 10 May 16th, 2005 10:04 PM
