Overheating...trying to head to MAR...help - Page 2 - Defender Source
Old October 3rd, 2014, 05:51 PM
Originally Posted by tebby View Post
Hoses are pressurizing. Jake...only thing I just thought of is a 95 water pump is different than the 97...and some of the discos. Hope the Hayden still bolts up?
They are different!
Old October 3rd, 2014, 06:18 PM
For future reference, if you turn the temperature control for the a/c all the way back (warmest setting) the compressor will not run but the condenser fan will. There is no need to pull fuses or disconnect anything. This may not be the case for all Defender a/c systems, but it is for my '95.
Old October 3rd, 2014, 07:49 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Why do you think you are overheating and under what circumstances? The fan only locks up when the temp starts to rise. Generally they can be stopped easily about 95% of the time. When they do lock up you can hear the difference. If the fan has failed it may just be masking another issue ... For example is the radiator hot at the bottom? They can sediment up and have poor flow. When you do get to mar you way want to do some more investigations.
Temp gauge normal at 50-70mph. As soon as I stop or proceed slowly...temp gauge rises. Got the temp gauge to rise while parked w tach around 3k for 4-5 mins. As far as I know I have original radiator w 124k miles...so I know I prob need to replace that as well. Will was able to order me the correct part and replacing in the am. Will see what happens.
Old October 3rd, 2014, 09:10 PM
Will is the best. Make sure you have the right tools to swap it.
Old October 4th, 2014, 07:35 AM
Ok so you have one of 2 issues. Insufficient cooling capacity or excess heat being generated. The fan clutch may or may not be working and changing might help but won't solve this.
Assuming you aren't losing water I would suggest a few things. Radiator is most obvious. Might be blocked at the bottom restricting the flow of water round the engine. You can check this but seeing if it's cold at the bottom when the top is hot. Solution is new rad, re-core or maybe a flush.
Another possibility is the water pump. If it's corroded away internally it might not be moving enough water.
The other issue may be you are generating too much heat ... This means that heat from combustion is getting straight into the water. That would suggest a head gasket or cylinder head type issues. You would experience some water loss at some point.
Good luck ..!!!
Old October 4th, 2014, 11:18 AM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
+1 for water pump
Old October 4th, 2014, 12:25 PM
Since the fan clutch is easy to replace don't hesitate to replace. However given that temps aren't high now replacing the water pump or at least adding one to your parts bin would be prudent.
Trying to help a friend with her 02'ish suburban airbornrover Misc. Chit-Chat 7 October 21st, 2011 08:54 AM
110 overheating or head gasket bcourtney Defender Technical Discussions 13 October 15th, 2009 09:37 PM
Help.....overheating isuue Frankie Carbone Defender Technical Discussions 3 November 11th, 2006 01:09 PM
Help! Overheating and sputtering! kjh888 Defender Technical Discussions 9 July 7th, 2006 12:40 AM
I'm trying to get the automatic gear shift handle off and I need some help KeithElisa Defender Technical Discussions 4 November 30th, 2004 12:01 PM
