Overheating....still.... - Defender Source
Old June 26th, 2005, 04:11 AM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Ok, I'm looking for more suggestions as to why I'm still overheating.
So far I've replaced the fan clutch, thermostat, and pulled and rodded the radiator.
Symptoms:
When driving around town I have no problems, i.e. driving to work, the store etc. When driving longer distances like 30+ miles I start to see it. Temps run fine until I slow down like get off the freeway. Then the needle quickly climbs to redline and I shut it off. If I let it cool for 5-10 minutes it gets cool enough to get moving again and once I get up to speed it's fine again, running a bit hot actually but nothing major. The fan is spinning so it's not the fan clutch as I replaced it with a brand new one. Nothing has been done to the engine lately.
My next guess is water pump. Possibly not moving coolant at maximum efficency. Moving enough through the radiator to keep it cool at speed with airflow over the radiator but once slowed it can't keep up. What else could it possibly be?
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old June 26th, 2005, 07:50 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Head gaskets or a cracked cylinder liner maybe?
Jimmy Buffett
Old June 26th, 2005, 09:46 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Check out this thread: http://www.defendersource.com/forum/...apa+block+test
Also, if it were me (and it was) I would get a block test kit from Napa is #700-1006 and check the radiator fluid for exhaust gasses (just follow the instructions with the kit). It is like $50, but you can use it and reuse it.
Old June 26th, 2005, 01:13 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Test the gauge. If it's like the 93, there's a chip between the sender and gauge. Could be any of the three -- sender, 'conditioning chip' or gauge.
Old June 26th, 2005, 03:05 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
It's definitely overheating. There is no chip on mine as I had the bezel off yesterday too. I'll be checking for engine gasses in the coolant as soon as I can. For now, it's sitting in the garage thinking about what it did.
overheating
Baffling Overheating Saga Trevor Tarr Defender Technical Discussions 51 May 20th, 2010 10:41 AM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Overheating Question PT94D90 Defender Technical Discussions 10 July 12th, 2005 04:39 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Overheating fun... Trigger Defender Technical Discussions 10 May 16th, 2005 10:04 PM
