Overheating in the Arctic - Defender Source
Old February 14th, 2010, 03:19 PM
61rover's Avatar
61rover
John Crouse
Went skiing yesterday and truck sat in the parking lot all day. It was very cold (15-20 degrees). At the end of the day, I headed up Berthoud Pass, and the truck began to overheat. Once committed, I couldn't turn around (a horrific accident closed the road behind me). I stopped at the top of the pass and let it cool for a bit. Headed down the other side, still hot. Got to a gas station and popped the hood. Coolent was a little low, but not much. I added a bit and started up. Temperature went right to 180. No more problems.
Trying to understand what happened. It doesn't make sense to me. Any thoughts?
Old February 14th, 2010, 03:38 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
How old, what mix is your anti-freeze? Unlikely, but a partial freeze of your radiator could have partially blocked the flow?
Old February 14th, 2010, 04:27 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Air lock in the inlet manifold? is there a little pipe running from the inlet manifold to the radiator? If that blocks it can lead to air gathering up there which then leads to overheating.
Mike Hammond
Old February 14th, 2010, 08:10 PM
61rover's Avatar
61rover
John Crouse
There was clearly some sort of obstruction. I just don't know if it was air, ice, or something else.
I think it was the act of depressurizing that solved the problem. It was like a switch. It immediatley went to normal.
Old February 14th, 2010, 11:44 PM
61rover's Avatar
61rover
John Crouse
Did it again tonight as we were leaving dinner. Ran all day with no problems. I need to figure this out.
Old February 15th, 2010, 12:30 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Check your coolant to see what temp it can go down to.
I would also check that your thermostat is working properly.
Old February 15th, 2010, 04:39 AM
mikeslandrover
Mike Hammond
Sounds more like a sticking thermostat. I'd change out the Thermostat and put in fresh, known concentration coolant while I was at it
Mike Hammond
Old February 15th, 2010, 09:22 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Stop driving it, these are the last motor you want to overheat a few times.
Old February 16th, 2010, 12:00 AM
61rover's Avatar
61rover
John Crouse
Replaced thermostat and filled it up. Coolant blew out the intake manifold gasket. Looks like that's the culprit.
Old April 27th, 2010, 02:42 PM
61rover's Avatar
61rover
John Crouse
Ok, it looks like my cooling problems are finally solved. Intake manifold gasket and then an upper radiator hose seem to have done the trick. Hose had a leak on the underside that I could not see until it completely failed. Truck has been right at 180 degrees since I installed the replacement.
Old April 27th, 2010, 05:22 PM
mikeslandrover
Mike Hammond
Glad to hear it's sorted.
Mike Hammond
Old April 28th, 2010, 05:47 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
If I were you, I would go to NAPA and get a block tester (about $50) that will test your coolant for exhaust gases. This will tell you if you have a porous block or a slipped cylinder---if you do, then your fixes will work in the short run but it may re-pressurize over time depending on how bad the leak. It is a simple test but one that I personally would find valuable since you don't want to be stuck in the middle of nowhere.
I personally had this problem and used a block sealant to solve it for years and years--although it reappeared recently and I rebuilt the engine from a new block.
Not saying that this is your problem, but you certainly had the symptoms and I would rule it out once and for all.
My 2cents.
overheating
Baffling Overheating Saga Trevor Tarr Defender Technical Discussions 51 May 20th, 2010 10:41 AM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Overheating Question PT94D90 Defender Technical Discussions 10 July 12th, 2005 04:39 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
overheating issue--viscous fan Davis Defender Technical Discussions 5 August 4th, 2004 12:11 PM
