Overheating and oil issues - Page 2 - Defender Source
Old September 6th, 2009, 06:08 PM
imeek
Isaac
Red 94 D-90 (SOLD)
Thank you Grover. I have some Liquid Wrench in the garage...I'll definitely try that too. I definitely like to take my time, as it's always more time and money if I screw it up.
Old September 6th, 2009, 09:48 PM
24in breaker bar and a 2in extension always worked for me on the t-case.
Odds are your cross seals are bad if the leak is at the back of the oil pan. Search this website for how to change them.
I would flush the radiator and check the fan clutch to make sure it is working. Also, make sure the AC electic fans come on.
Old September 6th, 2009, 10:27 PM
seems its best to have full access to the rear main seal and cross seals. the www. says just doing cross seals puts the rear main and risk as I was going to do my cross seals while I had the pan off. In theory they are really easy to change, it seems the rear main is very prone to getting messed up during this operation?
Old September 7th, 2009, 01:37 AM
I have never seen a rear main messed up doing cross seals. At the dealer we did dozens, if not 100 or more.
Old September 7th, 2009, 07:20 AM
So the starter does have to be removed to do these?
Old September 18th, 2009, 06:42 AM
imeek
Isaac
Red 94 D-90 (SOLD)
Here's what I've done so far:
radiator flushed
engine oil changed
t-case oil changed
trans fluid changed
Going to change the fluids in the diffs and replace the fan clutch this weekend.
Truck still has strong exhaust smell. Is this normal for a D90 with a badger top? I don't have a MIL, but should try swapping the temp sensor? It might also be an exhaust leak. The cats are rattling a bit, so I'll take it to a local shop for the "full monty".
Old September 19th, 2009, 03:41 PM
imeek
Isaac
Red 94 D-90 (SOLD)
So this is strange...the fan clutch that I got from AB does not match the one on my truck. Furthermore, the fan does not fit (holes don't line up) the new fan clutch.
Did the early 94 trucks have a different fan assembly? It came off, as described here on the site (reverse threaded). The new one seems that it's reverse threaded also.
pics:
ID:	21614   Click image for larger version
Old September 19th, 2009, 08:09 PM
the on the right looks like the one on my Classic, the one on the left looks like the one on my left, based on the end photo. That fan also looks like the fan on my classic.
Old September 19th, 2009, 08:46 PM
imeek
Isaac
Red 94 D-90 (SOLD)
Thanks Phillip. I guess I'll be ordering a fan too.
Old September 19th, 2009, 08:59 PM
It might be the right fan, mine could be wrong IDK. Id like to try some of those flex-a-lite fans I see on the Summit Racing site.
Old September 21st, 2009, 11:25 AM
Call Eric at AB and he will figure it out.
Old September 28th, 2009, 10:59 PM
imeek
Isaac
Red 94 D-90 (SOLD)
This is interesting...I received a viscous fan clutch from Rovers North this afternoon that is just like the old one I replaced (I got impatient and ordered a "replacement" from RN too). When I called Atlantic British they said I had the right "replacement" and told me to order a replacement fan. The new fan came first so I mounted it and got everything running.
Now I have another fan and fan clutch that are compatible, but not on the truck (and different than the replacements from AB). So who is right? LOL anyone need a fan and fan clutch?
overheating
Overheating in the Middle East Cmikefly Defender Technical Discussions 25 June 6th, 2010 02:20 PM
Oil Cooler line kit! Eric Siepmann Defender Technical Discussions 22 February 20th, 2007 10:09 PM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Help! Overheating and sputtering! kjh888 Defender Technical Discussions 9 July 7th, 2006 12:40 AM
Tailgating the overheating thread by steve bd90 Defender Technical Discussions 1 April 4th, 2006 12:34 AM
