overheating - Defender Source
Old June 25th, 2010, 06:03 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
overheating
I have a 94 d90 with a/c installed. when I leave my truck idling with the a/c on it overheats. If I turn off the a/c it doesn't overheat. Any suggestions?
That is why it is called a short cut. If it was easy it would just be "the way."
Old June 25th, 2010, 06:29 PM
Don't turn on the AC...problem solved.
It has been very hot in the South the past few days, even my Yukon's temperature went up a bit, when I left it running when I ran into my office for 15 mins.
I am guessing that the increased heat, with the extra strain on your engine, by leaving the motor on and the AC running is contributing to the increase in temp.
Old June 26th, 2010, 11:22 PM
texmoto
david summers
99 Discovery II
Are the AC fans spinning? What about the age/condition of the viscous coupling? Have you sprayed/cleaned the radiator?
Old June 26th, 2010, 11:29 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
the fans seem to be functioning correctly. Not sure about the viscous coupling??? The radiator is clean.
Old June 27th, 2010, 04:09 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Are you sure it is actually running hot? Mine did the same thing with the a/c on and turned out to be a bad ground in the gauge.
Old June 27th, 2010, 08:01 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
there was coolant boiling out of the overflow. It doesn't get hot without the a/c on, so when I leave the truck idling I am just turning off the a/c.
overheating
Baffling Overheating Saga Trevor Tarr Defender Technical Discussions 51 May 20th, 2010 10:41 AM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Overheating Question PT94D90 Defender Technical Discussions 10 July 12th, 2005 04:39 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Overheating fun... Trigger Defender Technical Discussions 10 May 16th, 2005 10:04 PM
