overheating - Defender Source
Old April 26th, 2009, 11:17 AM
derickson
Dennis
95/D90
overheating
I know there were several threads on this topic, but I could not find the details I was searching for. I have only had my D90 about 8 months and and only drove it occasionally since I purchased it and had no heating issues until this weekend. It had been sitting for a couple months and I took it out in the 80 deg weather and got stuck in traffic and noticed the temp gauge slowly went up the the edge of the red. This happened after sitting still for about 15 min. When running on highway or even driving around in the city, the needle stays right in the middle. Rather than let it overheat, I shut it off to cool. The expansion tank did not overflow nor did I smell antifreeze, so I didn't technically overheat.
I recall seeing a thread that mentioned how to check and see if the fan was engaging correctly. When the truck was running and parked, the clutch fan was engaged and blowing air. When I turned the engine off, I grabbed the fan and it was very easy to turn. I thought the thread mentioned that it should be hard to turn if the engine was warmed up and not moving? I don't have any auxilary electric fans on the truck. Could this just be as simple as getting a new fan clutch? If not, I guess my next step would be to have the cooling system flushed? Any other thoughts? Sorry, I now there are a ton of threads on this, but I could not find the details on the same sympton as this.
Dennis
Old April 26th, 2009, 11:35 AM
madcowdungbeetle
Carter
Your fan clutch is gone.
Replace it, or remove it and install electric fans in its place.
Old April 26th, 2009, 11:43 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
To add on top of that, I'd also make sure there isn't any gunk built up between the fins in the radiator. Pull the grille off and see if you've got any leaves, bird remains, mud or other crap in there.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 26th, 2009, 11:50 AM
Yes on all fronts. Avoid the aftermarket fan clutches. I have seen several fail very quickly.
Ron
Old April 26th, 2009, 05:26 PM
derickson
Dennis
95/D90
Thanks for the info guys. I did check for junk in the radiator and it looks clean, but I need to pull the grill off to be sure. Good advice on the aftermarket fan clutch. I will go OEM and hopefully that will fix the problem.
Old April 26th, 2009, 06:18 PM
Grover's Avatar
Grover
Wouldn't hurt to get it flushed as well.
Old April 26th, 2009, 07:45 PM
Ron
You are the only person I have heard say this. Most everyone talks shit about the stock replacements. ive tried aftermarket fan clutch and it doesnt appear to work any better that stock. The replacement that I got from autozone had the same part number as what I removed. It was a "torgflow" I think the best option would be the electric fans but even they arent perfect. I think these low mileage (relatively speaking) trucks can benefit from a serious cooling system flush and radiator rodding.
Old April 26th, 2009, 09:48 PM
By the way, I am not talking about the autozone ones (I don't have enough data points with those), I am talking about the ones bearmach et al were selling. They would work for a short while and then lock up permanently.
overheating
Baffling Overheating Saga Trevor Tarr Defender Technical Discussions 51 May 20th, 2010 10:41 AM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Overheating Question PT94D90 Defender Technical Discussions 10 July 12th, 2005 04:39 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Overheating fun... Trigger Defender Technical Discussions 10 May 16th, 2005 10:04 PM
