Overheat or not - Defender Source
Old March 1st, 2013, 11:32 PM
atpick's Avatar
atpick
Andy
1990 110
Overheat or not
So I finally got around to replacing my temp sender today. I have been driving around with it inoperative for two years with no issues (I know I should have done this earlier). Any ways after driving around for ten minutes on a cold soaked engine my temp gauge looks like this. Soooo.....has my engine really been overheating for two years and I didn't know it or did I buy the wrong temp sender. I installed this one which is for a 3.9l but was told buy rovers north that it was the same for a 3.5L which I have.
http://shop.advanceautoparts.com/web...rm=temp+sender
Thoughts, overheat or wrong sender?
Old March 2nd, 2013, 07:37 AM
Makes me wonder if that's a diesel gauge. Wy not just do a VDO? If you used thread tape that could cause you to get a bad reading. Have you been able to check the temp with an infrared thermometer?
Old March 2nd, 2013, 07:43 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It seems that the different year gauges have a different resistance so not all of the senders work correctly with all of the gauges. What color sending unit did you get? I used the green one but have the newer gauges on the 300Tdi.
Land Rover 110
Old March 2nd, 2013, 08:46 AM
atpick's Avatar
atpick
Andy
1990 110
The sending unit looked just like the one from the link, a golden color if you will. I haven't been able to use an infrared thermometer yet, will have to find somebody around her in Clovis that has one
Old March 2nd, 2013, 03:30 PM
atpick's Avatar
atpick
Andy
1990 110
So I tested the engine temp with an infrared thermometer and got anywhere from 190 to 214 degrees depending on where I shot on the manifold. I thought that was normal? Temp gauge still through the roof though....
ID:	67252   Click image for larger version
ID:	67254   Click image for larger version
Old March 2nd, 2013, 03:33 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Yeah those temps are pretty much normal.
Do you have a multimeter? We can measure the resistance of the sender and see what it's doing. I am going to guess you have the wrong sender for the gauge you have.
Old March 2nd, 2013, 03:40 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I would start by checking the ground or possibly running a dedicated ground to the gauge. If that does not resolve the issue I am guessing that you have a mis matched gauge / sender.
Personally I would go with a VDO and matching sender so you can feel safe / confident in the reading.
Old March 2nd, 2013, 04:16 PM
atpick's Avatar
atpick
Andy
1990 110
Looks like 215 ohms, unless I am measuring it in correctly
------ Follow up post added March 2nd, 2013 04:17 PM ------
Incorrectly I mean
Old March 3rd, 2013, 08:34 AM
Capt Milks's Avatar
Capt Milks
What was the part number of the sender you replaced? There are a few senders that will fit but only one that will give you the correct reading with your gauge.
Land Rover 110
Old March 3rd, 2013, 08:45 AM
atpick's Avatar
atpick
Andy
1990 110
TU333, link is in original post
Old March 3rd, 2013, 06:59 PM
atpick's Avatar
atpick
Andy
1990 110
Do you know what size VDO gauge is a direct fit, 2 inch or 2 1/16?
Old March 3rd, 2013, 09:21 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
2 1/16 ...i used a steward warner gauge .....white needle black ring matches alittle better i think
No Mall crawler here
Air Conditioner / OVERHEAT Flagg Defender Technical Discussions 4 November 3rd, 2010 01:33 PM
300tdi strange overheat Epsom_D2 Defender Technical Discussions 12 July 23rd, 2009 12:02 PM
overheat rover4x4 Defender Technical Discussions 3 January 21st, 2009 08:12 AM
overheat again Ray Bone Defender Technical Discussions 11 September 2nd, 2005 05:13 PM
overheat ONLY with AC? scubadanster Defender Technical Discussions 8 August 27th, 2005 10:23 AM
