overheat ONLY with AC? - Defender Source
Old August 24th, 2005, 02:45 PM
scubadanster
daniel park
1997 defender 90
hey gang~
my 1997 90 only overheats when the ac is on for a while....
i recored my radiator, have a new water pump....
why would this happen??
please advise~
much appreciated...
-dan
Old August 24th, 2005, 05:25 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Not sure on 1997, but on 1994 there is a temperature switch that turns on an auxiliary electric fan in front of the A/C radiator - make sure this is turning on your aux fan (it's located on the thermostat housing) when the A/C is running and the engine is warmed up.
You can probably jump the connector with a paper clip to see if the fan is working as well (simulating the switch being closed).
If you don't have that fan, I'm not sure what the problem could be - it could then be alot of things....that's the only "easy problem" I can think of.
Old August 24th, 2005, 06:47 PM
Does it happen on the highway as well as in traffic? Does the temp go into the red? How long does it take to get hot?
Old August 24th, 2005, 06:57 PM
That fan only turns on when your radiator/engine are about to reach critical mass (melt down) on a 97. If you still have your viscous coupling and fan pitch it and get electric fans instead. I live in Phoenix, drive a 97 with A/C and it made a huge difference once i switched to the Flex-Lite fans.
Old August 24th, 2005, 09:20 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I have the electric fans on mine and I'm going to install A/C in it & will soon have that third fan. I plan to wire them all to turn on with the same thermostat switch so I should have no problems staying cool with pusher and puller electric fans... that coupled with my 4-core radiator and soon a new water pump I hope I'm good to go.
Old August 24th, 2005, 10:08 PM
scubadanster
daniel park
1997 defender 90
yikes!
sounds like more money!
why didn't they place a better fan, a/c design??? grrrrrrrr.......
-dan
Old August 25th, 2005, 05:21 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I'm just paranoid of overheating I go out into the desert on very hot days sometimes - thus the A/C needs to be blowing cold and the engine not running hot.
You can always make that auxiliary fan come on at a lower temperature if you want to (have you checked to make sure it's working??) with an override switch, or a thermostat switch (one style you can find at your local auto parts store in the same section they sell electric cooling fans..).
Old August 26th, 2005, 01:53 AM
scubadanster
daniel park
1997 defender 90
a-ha....
good to know....
and no, i haven't checked my fan yet......not quite sure i know how to! =(
-dan
Old August 27th, 2005, 10:23 AM
The clutch fan is pretty easy to check. Try turning the fan while the engine is cool (not running of course!) , then try again when the engine is hot, it should be harder to turn it when the engine is hot, if it spinns pretty freely then your clutch fan is on the way out.
ac
1997 NAS Defender 90 AC kits ECR The Vendors Loft 2 December 22nd, 2009 07:18 PM
Overheating with AC on nmc Defender Technical Discussions 9 July 28th, 2009 08:13 PM
WTB 97 NAS D90 AC system ECR Wanted 7 July 16th, 2008 07:58 AM
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
overheat again Ray Bone Defender Technical Discussions 11 September 2nd, 2005 05:13 PM
