overhead map lights? - Defender Source
Old September 7th, 2004, 02:55 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Has anyone put in overhead flexy maplights? I have one for my cig lighter but it's just not ever in the "right" position when I need it.
If you have, can you share some pics?
Old September 7th, 2004, 03:04 PM
Not flex but very bright, I can see everything in the front or the back of the 90.
This is the light, I had 2 but broke one while wheeling. Only problem is the getto mounting system (zip ties).
http://foglights.com/msc.html
Old September 7th, 2004, 03:47 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Talking
What is that white hose thing on the roll cage. Does that go to a camelback...
Old September 7th, 2004, 03:55 PM
LOL no it's the air hose for my steam whistle.
Old September 7th, 2004, 04:14 PM
ronward's Avatar
ronward
Redsrover
None - sadly
No pix at the moment, but I mounted a cheap but bright headlamp in the same spot on the overhead roll bar in my 90. It was simple to just tighten up the elastic head band. I suppose it is sort of ghetto, but if you know my wiring skills you understand why I went "cordless".
Old September 7th, 2004, 07:07 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Two things: 1. I replaced the rear view with an aftermarket mirror with compass, external temp gauge and twin reading lamps. 2. Hella map light with 19" neck hard-mounted to the rear of the cubby. Front or back passengers can use it.
Old September 7th, 2004, 07:47 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Doug,
Good idea for the map light on the cubby - I was wondering where I was going to mount one myself.
What rear view aftermarket mirror did you choose?
Old September 7th, 2004, 08:20 PM
Doug's Avatar
Doug
Doug Walker
Can't remember the brand. They are not cheap. I searched around a lot and finally found one I liked. But it is one of the most used upgrades, especially the temp gauge, I've done. (Guess you've gotta be into it! )
Old September 7th, 2004, 08:44 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Check out this guys' mirror - complete with a display screen (in this case, tied to a rear-view webcam). I don't know if I need that, but... that's a pretty cool mirror (as far as mirrors go...)
http://www.digitalww.com/Miror_install1.htm
Old September 7th, 2004, 08:51 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
hey hey hey what's soo bad about zip tieing things on a some what permanent basis??? my CB and amber LEDs are tied on with them. Haven't found the modivation to get metal to bend into the right shapes.
Jimmy Buffett
Old September 9th, 2004, 03:26 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Dave
I spotted this on the EE. Apparently, Ho swapped out his Disco OEM for this aftermarket. You might give him a buzz if you're interested.
DJ
ht, lights
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
flickering lights nykx Defender Technical Discussions 1 November 12th, 2004 06:10 PM
Back lights all out vnrover Defender Technical Discussions 7 June 21st, 2004 12:04 AM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
