Overdrive for Late 60's Series IIA - Defender Source
Old May 10th, 2013, 01:45 AM
Jkkidd00
Kevin
1967 Series IIA 109 NADA
I'm thinking about purchasing a Series IIA from a friend on the west coast. However, it does not have overdrive and will of course have a few issues getting to a higher speed for highways (though I have no plans to speed around on the 101). Does anyone have any advice or experience on installing the overdrive? How much do the parts cost, and where could I find them? Any suggestions as to what I would be getting into? The engine is the 2.6L.
Old May 10th, 2013, 01:56 AM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
I'm not sure if they're still in business but I purchased a Wise Owl overdrive for my previous Series-IIA. Worked great for the couple of years I drove it. Sorry, but I don't recall the cost but it was fairly straightforward to install.
You might also check the wheels. 16" wheels will give you better road speed than the earlier 15".
Old May 10th, 2013, 07:38 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
edit: whoops I'm thinking series.. were faireys around and kicking in 90/110's / Defenders? not sure.
Fairey od's are available all over, used. The rebuild parts are available.. They hold small amount of oil and leak, and so many of them develop a loud whine hence the need to rebuild. 4-800$$
Global Roamer makes the Roamerdrive. Brand new parts, new(er) design, holds more oil, shares it with the transfer case so they don't have the lubrication issues of the Fairey. Perhaps not as well long term tested, but all reports I've found are good. $1500
Install is bolt on, with some sheetmetal cutting to mount the shifter handle
Old May 10th, 2013, 08:16 AM
Or put some RRC thirds in that have the higher 3.54 ring and pinion. You can usually get them for peanuts and the effect is similar, 'cept you can never get out of "overdrive".
I know some will jump all over me for suggesting this, but if you are doing mostly street driving, I think it's a good option. There will be occasions when the engine will run out of wheeze on hills, but that's part of the Rover experience. Heck, if you don't like it you can always put on an overdrive.
Old May 10th, 2013, 10:35 AM
61rover's Avatar
61rover
John Crouse
Fairey Overdrive is cheap, pretty bulletproof and easy to install.
series
Series IIA 88 Rolling Chassis and 2.5 Turner engine, tub, drivetrain, etc Macker For Sale - Parts 21 July 24th, 2013 11:20 AM
1962 Land Rover Series IIa 88'' refurbished Mike Sandone For Sale - Vehicles 2 October 22nd, 2012 04:25 PM
Series IIa short wheel base TDI Guy Wanted 3 August 12th, 2004 01:15 PM
Great looking Series IIA on EBay boshea Misc. Chit-Chat 3 April 24th, 2004 12:14 PM
