Overdrive aus Canada - Defender Source
Old November 8th, 2014, 04:49 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
I like the plug 'n play way!
Delivered in a wooden box!
Inside pure mechanical stuff.
Additional an extended oil pan had been asked for.
Time to check the width of the incomming wheel.
It was the right one!
The taper bearing has to be removed and set back to the new shaft.
The new version just preloades the bearing by a chrust whasher. We call it "Tellerfeder". But it's a thick one. I like that way. That's engeneering. Just have a look at the direction, that's all!
The lever bracket is now mounted to the transmission gear housing.
That's the great!
Dafür muss natürlich der Getriebetunnel wieder herunter. Aber mit verbautem Spezialgegengalter ...
... ist auch das kein Problem.
Done!
The linkage is connected with left- and righthand threads. Easy to adjust the right position of the handle.
I bend the handle a little bit. No collusions with others anymore.
The new grommet has a glued in third one.
Also new: the filling screw needs a 28mm spanner and there is a spy screw in the middle!
Best of all: a notification reminds you about the oil! So you don't need to ask this question here. Great!
I like this oil pan!
On the uppermost right you will have the look at this small sheet of stainless steel. This bracket carries the heat shield against the exaust pipe.
But I got an email from the owner, just minutes ago:
He arrived safe and sound at home.
But
without engaging the overdrive!
There was a terrifying noise when he tried it.
Has anyone any idea what's going wrong here?
Help is needed!
Old November 9th, 2014, 06:24 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
What's up?
No suggestions?
Old November 9th, 2014, 07:51 PM
Phone roamerdrive direct and ask them. They are very helpful and knowledgable
Old November 9th, 2014, 07:52 PM
skupetz
Gustaf Kupetz
NAS110, HCPU, Disco, Toylander, 2
(R)overdrive
I just got one as well. I might suggest it's the way it was engaged. I would contact the guys up in Canada, they'll sort it out in the AM.
-Gustaf
Old November 9th, 2014, 07:53 PM
87 D110 (Ruby)
a comment: Why did you need a 6th gear? ... fast lane on the Autobahn
Old November 10th, 2014, 02:38 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
-Gustaf
Thanks Gustaf!
You're right. The way is much longer than I suspected!
Everything is ok now!
The owner is happy and I'm able to take a napp.
Old November 10th, 2014, 03:40 PM
LR Max
Thomason, Max
1973 Series 3 109
I had issues with mine, the shaft connecting the overdrive to the handle was too long and the lever was interfering with all the other levers. So I couldn't engage it.
A few measurements later and a pipe cutter, we are in business.
Dunno, just a thought.
Old November 10th, 2014, 04:15 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Length from eye to eye should be 530mm (about 21")
I shortened it to get both of the levers in the same position.
Ok, only idiots like me will do that!
Old November 10th, 2014, 08:09 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
I have been running mine now for about 3 weeks, works perfectly. Had it installed by my mechanic, he's done several and did mention that they had problems with interference from the other levers. He made some adjustments and it's been fine.
You get a bit of gear noise for the first 1,000 km's or so as the gears break in. (very slight, nothing more than what you hear with a rebuilt transfer case) Once you are at about 1500km's change the oil and you should be set.
The additional gear is perfect for highway driving. (why didn't I do this when I had my 90??) Doing about 110Kmh the engine isn't working so hard. I have a 400k trip in a couple weeks, so I am looking forward to seeing what kind of fuel economy I am getting. Currently in the city I'm getting about 10L per 100KM (about 23 MPG).
Call Ray at Roamer, He's always eager to help.
Also, engaging and dis-engaging the overdrive is a much slower action than shifting the regular transmission. You have to shift slowly, from the dis-engaged point forward, it stops slightly in the middle (neutral) and pulls it's self into the engaged position. (much like learning to shift a manual) you have to "feel" your way in and out a little, and it will become obvious what the speed to shift is. If you "cram" it forward or back, you will grind.
Contact to buy Slotted Bushings from AUS? LRNAD90 Defender Technical Discussions 8 September 20th, 2013 12:51 PM
Lt95 Overdrive Wanted For 1984 D110 ctrover Wanted 4 April 13th, 2008 09:44 PM
Overdrive: Benefits & Installation Erimus 1 Defender Technical Discussions 6 February 21st, 2007 10:45 AM
overdrive lobster Defender Technical Discussions 11 May 9th, 2005 08:30 AM
Rocky Mountain Underdrive/Overdrive WBDISCO Defender Technical Discussions 14 January 10th, 2005 11:14 PM
