overdrive - Defender Source
Old May 4th, 2005, 02:25 PM
lobster's Avatar
lobster
Rob Goodall
1995 D90
overdrive
Has anyone tried the overdrive from this company?
http://www.roverdrives.com/index.htm
1995 D90 ST
1999 Super V8
Old May 5th, 2005, 01:50 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Rob,
This is semi-on topic... but since nobody answered you I figured I'd give you the courtesy... (don't worry I know how it feels... sometimes mine don't get answered).
I don't know if you'll find too many on this board that have tried the overdrive because in their own words:
"...At the present the Roverdrive is only available for 4 and 5 cylinder models as tests on V8 powered Land Rovers have not been completed..."
And the majority of users on here, since it's mainly a NAS D90 board have v8's... But I'm interested to hear as well.
On another note... I will say that I purchased a rooftop tent from this company and they took care of all the customs 'shtuff' at FedEX in Jacksonville, Florida and their customer service is top notch. If you need concrete answers though, the owner they told me is usually 'on safari' so you may have to wait some time to get answers, but hopefully they'll have a 'tech team' in that could answer your questions and whether or not their 'RoverDrive' has been fully tested on the v8.
Hope this helps.
Nicholas Orros
Old May 5th, 2005, 02:48 PM
lobster's Avatar
lobster
Rob Goodall
1995 D90
Thanks. I have been in touch with them via email and he said that "We have Rob and customers seem very pleased with it. Ray"
I am still thinking about it. 1250.00 for the unit. I am just tired of driving down the highway at 62 mph with the tach at 3000. It just sounds bad. One of these days I will buy a tow vehicle, this might be the short term solution. Thanks again for your reply Nicholas
1995 D90 ST
1999 Super V8
Old May 5th, 2005, 03:13 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Rob, are you sure you're using 5th gear? Or do you have 4.7 diffs? I'm sure that to get my tach at 3000 rpms I'd have to go 75 or faster in 5th.
Bigger tires = lower RPM Someone has to have one. Did you ask them for references to customers who have used them?
Old May 5th, 2005, 03:55 PM
lobster's Avatar
lobster
Rob Goodall
1995 D90
I have 35's with 4.75 gears. That is a good suggestion Mike. I will see what he says. 5th gear come on, I might be slow but ouch.
1995 D90 ST
1999 Super V8
Old May 5th, 2005, 04:31 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
No jab intended! Wow, those 4.75's make a huge difference. On my way home tonight I found that I only do 2400 rpms at 70 mph.
Old May 5th, 2005, 06:31 PM
lobster's Avatar
lobster
Rob Goodall
1995 D90
The speedometer in my truck reads 95 at 62 mph. I had to change to a disco chip if anyone is interested in the stock d90 chip it is for sale cheap
1995 D90 ST
1999 Super V8
Old May 5th, 2005, 06:58 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Rob, you should do the VDO speedo and that will take care of that problem. Wasnt Rocky mountain working on an underdrive/overdrive all in one?
R
Legend in My Own Mind.
Old May 6th, 2005, 07:41 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Yeah, you're right Randy,
I was about to revive an old thread reguarding the over/under drive when I saw lobster's post.
http://www.defendersource.com/forum/...ght=underdrive
Man, would that be handy....
Old May 6th, 2005, 10:12 AM
lobster's Avatar
lobster
Rob Goodall
1995 D90
That guy's email address is expired
1995 D90 ST
1999 Super V8
Old May 9th, 2005, 08:30 AM
d90Monkey
James
1995 D90
I too am curious about an Overdrive unit. I have the lower gears and hate revving the crap out of the engine just to hit 60+ MPH. Considered doing the chip mod to get around the limiter but still dont like adding stress to a 10 yr old engine. What does the VDO mod do? Am I correct in assuming it is just another way to circumvent the rev limiter?
Overdrive for 110 with 2.8 TGV Santiago Defender Technical Discussions 96 March 6th, 2011 09:36 PM
Fairey Overdrive 98 HOO Wanted 1 November 23rd, 2009 04:30 PM
Overdrive lateapex For Sale - Parts 8 June 22nd, 2009 11:50 PM
Lt95 Overdrive Wanted For 1984 D110 ctrover Wanted 4 April 13th, 2008 09:44 PM
Overdrive: Benefits & Installation Erimus 1 Defender Technical Discussions 6 February 21st, 2007 10:45 AM
» Defender Registry
Chapolin
aprellvitz
Max
juddy
Add your Defender
