over heating when idling - Defender Source
Old August 15th, 2016, 02:43 PM
Defender_90
Kevin Doonan
1999 RR HSE
Hi All,
'94 defender 90 is overheating when idling.
Pretty sure this has to do with the water pump coming to terms with its age.
Bit just wanted to confirm that it would be possible for the pump to circulate coolant while driving, thus not overheating, but when idling (lower RPM), the pump does not have sufficient power to circulate the coolant.
side note; engine thermo in the red on the dash, panis sets in, pull resi cap off........all can imagine what happend next.
Thanks in advance!
Kevin
Old August 15th, 2016, 02:48 PM
rxcrwlr
Rover Dude
looks like a bad fan clutch
Old August 15th, 2016, 02:51 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
x2 on the fan clutch. Typically when the water pump starts to go, it will start to leak by design to let you know. Replace the fan clutch and see if that does it.
Old August 15th, 2016, 03:17 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
X3 on fan clutch.
Old August 15th, 2016, 04:15 PM
Defender_90
Kevin Doonan
1999 RR HSE
Thanks team for the quick response, I am going to try and get that sorted this week.
Hopefully that does the trick.
Any suggestions on $139 version versus the $300+?
Old August 15th, 2016, 04:20 PM
Test it first.... When too hot, pull over. Are both the hoses in and out of the radiator HOT? If so, check the fan.
Carefully take a rolled up newspaper and try to stop the fan. If it stops the viscous unit is dead.
Old August 15th, 2016, 04:36 PM
If its your fan clutch, I've run one of these on my 4.2 for a couple years now and its worked well.
1987-1995 Land Rover Range Rover Fan Clutch - Cooling System - Hayden 87-95 Range Rover Fan Clutch - 285-05154125 - PartsGeek
It will thread right onto the defender v8 waterpump.
For the difference in price you could likely switch to the classic fan as well if necessary.
Over heating issues... Fan recommendation please Davis Defender Technical Discussions 3 August 7th, 2012 01:16 AM
Engine dies while idling Coug D90 Defender Technical Discussions 2 December 4th, 2010 01:36 PM
CEL light when idling rlynch356 Defender Technical Discussions 7 May 14th, 2010 12:59 PM
Over heating issues on new 4.6 build anthony Defender Technical Discussions 7 August 1st, 2007 02:32 AM
over heating Big D Defender Technical Discussions 4 January 5th, 2007 04:14 PM
