Over heating issues on new 4.6 build - Defender Source
Old July 29th, 2007, 10:53 AM
anthony's Avatar
anthony
Anthony Leung
1995 D90SW #51
I just replaced my POS 3.9 with a 4.6 with an after market comp cam, new lifters ect. I'm having issues with the engine running hot, i have already recored the radiator with a 5 core. Not sure what it would be at this point clutch fan was also replaced. An oddly i'm not having issues running in 4L running slow most of the over heat issues are more constant 3-4K RPM range at highway speeds. Was wondering if anyone else who's done this swap has had this issue and what did you do to repair the issue. I am tempted in cutting vents into the hood which alot of members have done it seems. But i would like to find the issue before i cut.
1995 D90sw #51 (Converted to ST)
1997 D90ST
2006 LR3 HSE (untouched... for now)
Old July 29th, 2007, 03:37 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I basically have your setup with the exception that I am running electric fans. My overheating was related to exhaust gases making their way into the coolant. I have a block tester from Napa if you want to check yours out and at least rule that out--I am in Boulder but work in Denver so we could always meet up sometime.
There are a lot of possibilities including inadequate flow of the coolant through your system. You can help check this by using a infrared thermometer and checking the temperature at different levels in your radiator and hoses and kind of (not really accurate) get an idea of your temperature gradients. This will at least tell you if you have hot water entering the radiator and cooler water exiting.
These two tests should at least be able to point you in the right direction. Other things to check are properly bled air from cooling lines, engine timing, your thermostat and the coolant pressure cap. These will be the most likely culprits.
Let me know if I can help.
Old July 29th, 2007, 10:48 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Vacuum advance working? Did you degree the camshaft? You may have to play with your timing and ignore the factory setting. Move it a degree or so and test drive a few times. Do you have A/C? Is the condensor clean enough for air flow. Can you install surround pieces to direct airflow through the radiator and keep it from bleeding past it or recirculating from the engine compartment?
Checking for exaust gases is a good idea as well. Need to rule that out on a new engine also.
Some things to consider.
JP
legend in my own mind
Old July 29th, 2007, 11:24 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I'm with Pendy, timing may be the issue and I've seen it happen a few times with recently rebuilt engines if the timing is really wacky. Since it's happening when the engine is under load, that lends a bit more to the theory of the vacuum advance in the distributor to possibly have failed, either the vaccum can itself or the lines leading to it.
However, also don't rule out a mixture issue either, as running lean for extended times may also cause overheating. Are you using the original injectors and computer from the 3.9? You may need to rechip and go with a higher flow rate injector, to go with the bigger engine... especially if you've done the cam. Got a Fuel/Air meter in there at all? May not be a bad idea, especially if you can spring for a wideband one that can do a data plot for you.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 30th, 2007, 01:51 AM
anthony's Avatar
anthony
Anthony Leung
1995 D90SW #51
Thanks guy's i'll give it a shot, Davis i'll pm you if i can borrow the tester. The cam has already been advanced 3 degree's but maybe it's too agressive. The water pump is actually new as well, and water flow seems good, no real way to test how much flow there is though. I've already poked around with a infared thermometer. I have not swaped out the chip on the ECU yet which might be some of the cause . Going to put a 4.2 chip in but there not so easy find anymore.
1997 D90ST
Old July 30th, 2007, 05:29 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am running the 4.2 chip in my ECU. I currently run 10 degrees of timing, and again, running just fine temp wise...
Old August 1st, 2007, 01:39 AM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
find drillbit on DWEB, he has some 4.2L ecu's I think?
Old August 1st, 2007, 02:32 AM
anthony's Avatar
anthony
Anthony Leung
1995 D90SW #51
funny, that's where i got the block from =)
1997 D90ST
4.0 to 4.6 parts? gtg067i Defender Technical Discussions 6 September 11th, 2010 08:40 AM
3.9 to 4.6 1995 D-90 boxerhips Defender Technical Discussions 5 January 25th, 2006 07:20 PM
four 4.6 18 in hurricane wheels mpheff For Sale - Parts 0 March 25th, 2005 03:39 PM
Pristine 4.6 D-90 for Sale on EBay Ntajeep For Sale - Vehicles 0 June 9th, 2004 11:23 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
