over heating - Defender Source
Old January 5th, 2007, 12:03 PM
Big D
Daniel Brown
over heating
The fan infront of the radiator between the radiator and grill has stop working. Its causing the engine to overheat. Any suggestions? If I need to replace it, is the a better cooling system to install? Is there any way to check if the fan is dead or it is an electrical problem. Thanks for the help.
Old January 5th, 2007, 12:22 PM
The little fan in front of the radiator is for the AC system. It kicks in to assist with the cooling at certain temperatures or load. Check and clean your radiator and make sure your engine fan and fan clutch are working correctly. Fan clutches do go bad.
You could always choose to add electric fans...
What year is your truck?
Old January 5th, 2007, 01:58 PM
Big D
Daniel Brown
95? What would cause the over heating?
Old January 5th, 2007, 02:57 PM
Grover's Avatar
Grover
Could be the thermostat...
How long after start up does it begin to overheat?
Old January 5th, 2007, 04:14 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
What would cause the over heating? LOTS! do a search then come back!
aftermarket heating module 97Ariesblu Defender Technical Discussions 6 February 19th, 2008 04:34 PM
Over heating issues on new 4.6 build anthony Defender Technical Discussions 7 August 1st, 2007 02:32 AM
2007 Defender details announced Kev Baldwin Misc. Chit-Chat 17 August 22nd, 2006 09:01 PM
Driveshaft u-joint install Buckon37s Defender Technical Discussions 14 March 15th, 2006 12:25 PM
using home heating oil in Tdi artm Defender Technical Discussions 17 October 19th, 2005 03:00 PM
