Over counter air filter? - Defender Source
Old June 12th, 2013, 07:54 AM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Is there a store who carries air filters over the counter? Say for a 86 ROW with snorkel canister? I have found oil filters this way for my 200tdi. Thanks for any direction!
Jason
Old June 12th, 2013, 10:40 AM
michael67's Avatar
michael67
Michael White
110 Tdi
I believe Carquest can get some. I know they can get a 300 Tdi air filter but not a 2.5 NA. Don't know about 200 Tdi.
Old June 12th, 2013, 11:26 AM
Which engine? I have cross over numbers for most...
Old June 12th, 2013, 02:18 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
It's a Defender 200tdi. Numbers aren't available.
Old June 12th, 2013, 02:49 PM
If it is a Defender 200TDI air filter suitable numbers are below:
Fleetguard AF-437KM
Baldwin PA1667-FN
Donaldson P101222
FRAM CAK 253
Land Rover NTC6660
http://www.defendersource.com/forum/...ad.php?t=40226
You will need to go to an industrial supply store that sells parts for industrial equipment, like CAT or CASE or such. It is a common filter size.
If it is a Discovery 200TDI filter, I don't have that number, but it might be on the forums somewhere...
Old June 12th, 2013, 03:05 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
[QUOTE="Red90;446025"]If it is a Defender 200TDI air filter suitable numbers are below:
Fleetguard AF-437KM
Baldwin PA1667-FN
Donaldson P101222
FRAM CAK 253
Land Rover NTC6660
If it is%
Old June 12th, 2013, 03:18 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Much appreciated! Suppose I'll check the local Tractor Supply first. Thanks again for the info
Jason
Old June 13th, 2013, 10:15 PM
Bolson
Ben Olson
1995 Defender 110
FYI the filter for a 743 Bobcat skid steer fits the 300 tdi perfectly
New Air filter box for HS 2.8 engine Santiago Defender Technical Discussions 6 November 17th, 2016 04:33 AM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
air filter box mattdh Wanted 1 September 14th, 2005 12:42 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
Air Filter Housing mgrgpg Defender Technical Discussions 1 December 20th, 2003 01:48 PM
