output shaft oil seal collar - Defender Source
Old August 9th, 2014, 04:02 PM
woza
Manny Backman
'68 109 3 door S Wagon R/H drive
How do you get the collar off without damaging it. Mine is damaged from the clam shell splitter and puller I used. Puller is bent so it is trash. Now I am going to take the small angle grinder to it and then split it done fighting with it. No other way to get it off unless i buy the tools from the UK. Then I may as well get a rebuilt gear box from Ashcroft because the tools are half the price of the rebuilt gearbox. Ideas for the next time round will be welcome. Just a little bit frustrated and it's beerthirty
Old August 10th, 2014, 09:40 AM
1. always buy a replacement oil seal collar.
2. you do not need the uk tool. just buy the cheap harbor freight puller. use the largest jaws. replace the cheap washers with grade 8's. clamp the jaws down tight on the oil seal collar and rip off with an impact wrench.
job done
Old August 10th, 2014, 05:56 PM
woza
Manny Backman
I will try that thanks Ed
LT77 Oil Seal Collar michael67 Defender Technical Discussions 2 July 21st, 2011 11:01 AM
LT77 Oil Seal Collar michael67 Wanted 0 July 17th, 2011 01:17 PM
XCase Rear Output Seal Viggen Defender Technical Discussions 3 August 26th, 2010 11:49 AM
Transferr case rear output seal redrover Defender Technical Discussions 4 July 29th, 2006 05:21 PM
Auto trans output shaft extension needed JCRover4x4 Wanted 1 June 15th, 2004 10:10 PM
