Outer Rear Oil Seal Leaking - Defender Source
Old March 23rd, 2014, 04:25 PM
BRAB
Brandon
200TDI in a RHD 1986 D90
Hello,
was replacing the rear wheel bearings on my 1984 ROW defender and while fitting the outer oil seal on the left side the seal in the brit-part kit did not fit as it was slightly larger than the hub itself. The previous owner completely left out the seal (probably due to the same problem) and that caused gear oil to leak up into the drum and out onto the inside of the rim and tire leaving a little pool of gear oil when i park. The same kit fit perfectly on the right hub assembly as well as the inside side of the left hub assembly but not on the outside of the left hub.
I was wondering if anyone has ever run into this problem? Instead of not putting a seal in there I notched out a piece of an old seal and fit it but of course this is leaking.
If anyone has any ideas let me know
Thank You
Old March 23rd, 2014, 04:41 PM
BRAB
Brandon
It is a 1984 Defender with drums at there rear and here is the kit I ordered which fits the right hub but not the left.
http://www.paddockspares.com/da2380-...end-of-ka.html
Old March 23rd, 2014, 04:55 PM
BRAB
Brandon
Outer seal 23
inner seal 12
Old March 24th, 2014, 05:48 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Really strange. I've never seen that seal, and never noticed that Microcat actually lists it for 87-06 Defenders, 89-98 Discoveries and 86-94 RRC's.
I'm having a hard time visualizing why you'd even need it.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Oil Leaking?? HELP, PLEASE ZachJackson Defender Technical Discussions 4 September 26th, 2013 11:34 AM
Swivel ball/seal leaking jaherring Defender Technical Discussions 1 September 18th, 2007 10:29 PM
Leaking grease seal Rover- Girl Defender Technical Discussions 2 September 18th, 2006 04:11 PM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
