Ospho, por15 and Pettit rustlok - Defender Source
Old May 14th, 2016, 05:59 PM
Naplm00
Matthew
So after a ton of labor I have my front and rear axles degreased, wire brushed and stripped of peeling paint.
Front axle is a mix of fresh white metal and rusty but wire brushed metal.
Rear axle is brushed rusty metal.
I'm going to hit both with ospho first. Then the question is weather to use por15 and a topcoat or Pettit rustlok and a topcoat.
Also can I use ospho then let it sit for a week or two before I paint it?
Old May 14th, 2016, 08:28 PM
seaswood
Diesel
Ospho
To use Ospho properly you need to wash it off or mix it 50% water - Ospho. Should become a white powder. It should be stable once it has dried. Por is made to go on rusty metal sitting should not bother the final result.
Poor-15 by itself is not supposed to last in sunlight for this they have a top coat they sell.
I used the por basically everything under the truck your choice.
Old May 14th, 2016, 08:42 PM
seaswood is right - ospho has detergents which will prevent adhesion of paint if you don't wash it off.
btw - Kleen Strip Prep and Etch is much cheaper than Ospho and is basically the same stuff. Save your $$$.
No idea about the other stuff.
Old May 14th, 2016, 09:04 PM
Naplm00
Matthew
I've never rinsed previously using ospho, thought it was just water and phosphoric acid?
Old May 14th, 2016, 10:30 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
por15 is fantastic but really spendy and particular on timeing if you want to paint over. Not sure I'd bother painting over it, but to each their own.
Good luck and please post pics whichever way you proceed.
Old May 14th, 2016, 10:46 PM
mostly that. there is also a detergent in there, which you can see in action if you put zinc in there.
the zinc will react with the phosphoric acid to form zinc phosphate and hydrogen gas. the evolved hydrogen will create a fine foamy layer, which is the detergent forming bubbles.
Either way, you gotta wash it off, acid and all. Unless you don't care
Old May 14th, 2016, 11:02 PM
Naplm00
Matthew
No I definitely care, ill add that step this time
Por15 drdread Defender Technical Discussions 16 January 16th, 2015 06:48 PM
ospho - seems to work as promised sonoronos Defender Technical Discussions 13 February 2nd, 2012 10:18 PM
POR15 and topcoat for other surfaces? Hoosier Defender Technical Discussions 10 February 13th, 2009 06:43 PM
ospho rust primer rover4x4 Defender Technical Discussions 3 May 7th, 2007 07:24 AM
B and C pillar and other stuff and stuff for trade bstraw Wanted 2 January 10th, 2007 12:11 PM
