Original hitch - Defender Source
Old October 31st, 2014, 08:11 PM
Spanish Fly
Carlos Soldevila
1990 Defender 90
Original hitch
I am planning on using, on very rare occasions, and for short trips, my 1990 defender 90 to hitch a trailer (has brakes) with a race car (total weight of about 3800-4000 pounds).
(I also own an LR3 that does the normal hitch work, but sometimes my wife has to use it, leaving the Defender to do the work!)
I have seen in the market other hitches for the Defender, but I am wondering if the original one I have will do the trick!
Old October 31st, 2014, 09:10 PM
Spanish Fly
Carlos Soldevila
1990 Defender 90
A UK towball is 50mm which is slightly smaller than 2" If it was for a small utility trailer, id probably run it, but since you are going to be towing a fair amount of weight, Id swap to a 2" ball.
-Jeff
thanks! Do you know if I can only change the ball itself (can I find a 2" ball that fits the hitch I have?), or do I have to change the whole hitch for a CLASS III RECEIVER HITCH like this one?
Name:	CLASS III RECEIVER HITCH.jpg
Old October 31st, 2014, 09:21 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
-Jeff
You're talking about less than 1mm. That's not going to be a problem.
Old October 31st, 2014, 09:38 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
Talking
Yea, just make sure your latch is tightened up well. there's a nut inside the socket.
Now the problem it looks like you WILL face is...
If your rover is anything like mine, the hitch you have will be like 8 inches too high...
My jeep has a much much lower bumper than the landy and i still run a 6 inch drop or lower for all my trailers. And that is also from a below the bumper mounted receiver.
Granted... if you can get a car trailer up that high, i'm sure the hitch will lower quite significantly when your front wheels come off the ground.
For that much weight, obviously you must have brakes. Probably the law for most places.. but I've seen things when traveling in the south east.... scary things.
Old November 1st, 2014, 05:44 AM
0.8 mm size difference should be accommodated by the trailers hitch. Uhaul does it all the time with its trailers to accommodate 2 in v 1 7/8, a far larger gap than yours.
Old November 1st, 2014, 10:43 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You need something like this, I can fit it on my 90 so you get an idea of the adjustment range.
I will be listing this tow plate & 50mm ball soon, it has fresh Galvanizing. Removed from my 86 90
Heavy piece of kit
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
hitch, original
Reinforced Tow Hitch TurkD90 Defender Technical Discussions 14 March 19th, 2005 12:22 PM
Rover ACcesoeies hitch? rover4x4 Defender Technical Discussions 20 February 7th, 2005 01:35 PM
Rover Accesories hitch. rover4x4 Misc. Chit-Chat 2 January 3rd, 2005 10:11 PM
hitch bike racks rover4x4 Misc. Chit-Chat 2 January 3rd, 2005 09:27 AM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
