Organizing wiring/electrical for accessiries...thoughts? - Defender Source
Old December 9th, 2006, 12:46 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
I'd like to organize the electric wires in my D90 for non factory installed accessories.
What's the neatest/correct way to do this?
Is there any type of wiring harness or relay bank that you would recommend as an easy solution?
here's what I have installed and what I need to install:
-aftermarket radio,
-rear work light,
-driving lights (not installed yet),
-CB radio (not installed yet),
-Aux plug (cig lighter type) (not installed yet),
and maybe more...
Thanks.
Paul
Old December 10th, 2006, 10:17 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I ran a heavy gauge wire from my battery box to a seperate fuse box in the seat box passenger side. I need to do some more clean up but I will run all of my extra stuff out of the seperate fuse box.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old December 10th, 2006, 10:41 AM
I am actually researching the same thing. I'm looking at the Painless wiring weather resistant auxiliary fuse block part 70207. it comes fully wired as a drop in.
description: http://www.painlesswiring.com/webcat...SearchField=14
here's a review: http://www.4x4wire.com/tech/fuse_block/
and available at: http://store.summitracing.com/egnsea...115+4294843287
Old December 10th, 2006, 01:47 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Blue Sea Systems makes some nice fuse panels that work well for aggregating all the fuses for those items in one place.
Old December 10th, 2006, 08:44 PM
I have a Painless 70207 mounted in my battery box which I have used for all my auxillary circuits - heated seats, aux lights, power outlets etc. It works well, is easy to sort, and is nicely constructed. I like having it in the seat box since then the wire runs are easy to the center console and I only needed to run a single lead from the main fuse box.
Old December 10th, 2006, 09:07 PM
Jim,
I would like to see a picture of that to gather placement ideas. Are you running single or dual batteries?
Old December 10th, 2006, 09:54 PM
I only have a single battery set-up right now. I've got the fuse box mounted on the innermost side of the battery box, on the little raised section where the jack sits. I dont think that would interfere with a dual-battery system.
Old December 11th, 2006, 07:06 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
Great Ideas!
Thanks!
Old December 11th, 2006, 09:16 AM
Michael
Michael
Discovery 1998
If didn't have enough clearance for the painless one, so I went with the centech AP1 (centechwire.com). I guess this is usually used for motorcycles, but it is a very nice piece.
Old December 11th, 2006, 01:40 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Hey Paul,
You may also want to check out Wrangler Power Products . I've bought breakers and fuse blocks from them in the past and been happy with the quality. I've attached a photo of one of their fuse blocks and manual reset circuit breakers that I had installed in an older truck. The Fuse block was rated for 80 amps (right arrow), and was fed with a 4 gauge cable to the 80 amp (left arrow) breaker, then to the battery. This was a twelve slot block. I plan to use the same setup in my 90 eventually, whenever I get the dual battery install completed..
Catalog Pages with these Fuse Blocks, scroll down
~Scott T.
'95 D-90 ST - AA Yellow
ac, electrical, ht, wiring
Thoughts? Portland to Chicago (almost) nycjdp Trips, Trails and Events 3 November 29th, 2009 01:36 PM
Theft Recovery 97 defender, Your Thoughts? ChiTown4x4 Defender Technical Discussions 0 November 26th, 2009 12:24 PM
RDS Fans...Keep N.O. in your thoughts Ragland Misc. Chit-Chat 1 August 28th, 2005 04:00 PM
hannibal thoughts?? scubadanster Misc. Chit-Chat 5 February 12th, 2005 01:02 PM
Thoughts on galvy chassis? dmarchand Misc. Chit-Chat 2 October 17th, 2003 02:09 PM
