Ordering a headlight relay harness - Defender Source
Old September 17th, 2011, 11:06 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I'm about to order the harness from Rallylights.com (Susquehanna Motor Sports), just not sure if its conventionally switched (my guess) or switched ground (which I would assume was done for spite).
http://www.rallylights.com/detail.aspx?ID=3730
or
http://www.rallylights.com/detail.aspx?ID=1247
ideas? yes I searched, admittedly not much.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old September 17th, 2011, 11:36 AM
They are conventionally switched.
Old September 17th, 2011, 11:37 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Thanks.
~2008 GTI TSI
Old September 17th, 2011, 11:38 AM
You will probably need extra wire to reach the battery.
Old September 17th, 2011, 08:27 PM
silverlight's Avatar
silverlight
Geoff
1993 Defender 110 NAS
It's a little more expensive, but not by much, I got the Painless H4 harness. Still have to install it but will probably do it this weekend.
http://www.summitracing.com/parts/PRF-30815/
http://www.amazon.com/Painless-Wirin...6305594&sr=8-1
Old September 18th, 2011, 04:30 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Yeah I'll probably extend the Red wire in order to reach the battery easily.
Thanks, but I'd like to give the business to this guy. He's local to me and I've spoken to him on the phone a few times about other stuff I was trying to find. good guy.
~2008 GTI TSI
Old September 18th, 2011, 06:04 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
You can put the red wire on the starter, no need to got all the way to the battery, I guess.
Cheers,
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old September 19th, 2011, 02:00 AM
CDeWan
Clay DeWan
5.3L beastie
wire
I am with Santiago on that one. I ran a heavy duty wire off the starter to the a small terminal box that I mounted by the coil so I could pull power when needed.
Old September 19th, 2011, 10:45 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Cheers,
good call, thanks
~2008 GTI TSI
Old September 23rd, 2011, 11:10 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Don't know if anyone's seen/installed these but it seems nice because it's plug and play........connectors are already made for Defender.
http://www.traxide.com.au/HL_kits.html
Old September 24th, 2011, 10:19 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I have an unused ARB headlight harness that I can part with. If any is interested send a PM.
Old September 25th, 2011, 10:44 PM
I used the ARB one, just run a hot from the battery to the engine compartment and mount the relays. Simple install
95' D90 - daily driver..
Old September 25th, 2011, 11:11 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Agreed, I've bought a good amount of stuff for them for rovers over the years, but they also proved to be a massive help sourcing a replacement HID bulb for my Audi. Took a ton of time to make sure they got me the right part at a significant savings over what I could source it from any of the audi places.
Old October 2nd, 2011, 05:22 PM
silverlight
Geoff
Question for you. I tried the Painless harness this weekend (just laid out the wires to check lengths), and it's not long enough to reach the passenger side headlamp on the assumption I mount the relays close to the firewall on the drivers side. (this is assuming I run the wire along the firewall with other wires and then follow the passenger side along wheel well into the headlamp).
Was the ARB harness long enough to accomplish this? Would like to keep the wiring harness running in the conventional routes...
Thanks!
Old October 3rd, 2011, 03:10 AM
Yes it was - the pass side fits easily. I mounted the relays onthe drivers side of the fender overhang on a small aluminum bracket i made from some sheet AL. I ran a constant + lead from the battery to the wheel well area and attached the harness there. This is also big enough for mounting Aux light harnesses etc when i insall them.
Old October 3rd, 2011, 10:26 AM
silverlight
Geoff
Thx, appreciate the help.
Old October 25th, 2011, 07:22 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I received the Susquehanna Motor Sports harness today, will probably install this weekend. Very impressed with the build quality. Very heavy gauge wire, he even added a jumper wire from the high beams to trigger my driving lights. Looks very good.
~2008 GTI TSI
Old October 27th, 2011, 05:34 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Installed the harness
I put the harness in today after work, honestly it couldn't have taken more than 10 minutes of actual work (not including laying it out, etc). Plug and play, ran the main hot and ground all the way back to the battery (may reroute that later). The difference in light is staggering. My low beams now are significantly brighter than my high beams were before. From when I made the call to when it arrived at my door (full disclosure we're in the same state) was 2 business days. He had me ballpark distances between relay mounting location, battery box and lights over the phone and custom cut all the lengths which were perfect. Thanks very much RallyLights.com very impressed with the build quality and speed. The 2nd to last pic was before then harness, last was after. I'll do some more pics at night if requested (as the harness is easily reversible, no cutting or drilling).
ID:	43199   Click image for larger version
ID:	43201   Click image for larger version
~2008 GTI TSI
Old October 28th, 2011, 08:13 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Just curious:
- where did you locate the relays? Engine bay? Inside the cab?
- where do you pick up the switching signal? From the steering headlight switch, from a plug somewhere?
- how is the stock wiring routed from the steering switch onward?
I've meant to do what you just did for a while but never got to it! :[ it seems so easy that I'm running out of excuses...
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 28th, 2011, 09:52 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
-Relays are currently located on the firewall with some other relays/electronics that were already there (picture 2). I may eventually move them inside the cab or in the battery box. They seem fine where they are though.
-The switching signal is obtained through one of the original headlight plugs (the other one I just left unplugged but tied back). Basically I flip the headlight switch and power is then sent through the OEM wiring, into the relay, which pulls power directly from the battery, and powering the harness' plugs which now feed the lights. Everything is easily reversible by just unplugging the harness, then plugging the original plugs back into the back of the headlights.
-The stock wiring is unchanged, other than the one headlight plug not being used.
~2008 GTI TSI
ht, relay
ARB Headlight Wiring Harness d90dang Wanted 2 August 2nd, 2011 05:40 PM
Headlight relay Palomino Defender Technical Discussions 4 June 10th, 2011 05:53 PM
ARB Headlight Wiring Harness Gore Ranger Defender Technical Discussions 39 May 30th, 2011 05:56 AM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
