Optimal plug wire routing - Defender Source
Old December 29th, 2014, 02:38 PM
Does anyone have a photo layout showing really well done wires?
I'm looking to solve some mis-fire issues and want to make sure I don't get cross sparking.
Old December 29th, 2014, 02:40 PM
do you have the little guides that the wires sit in? There is really only one way they can go with the guides.
Old December 29th, 2014, 02:46 PM
8 will always cross 4 and 6 - you may be able to route it between 3 and 4 but it'll still be close to rubbing up against those two. 8 is also the longest and there's often enough slack to run them uncrossed until the final guide, and run 8 out a little further from the other plug wires to where there'd be no chance of interference. 2 can be routed between 1 and 8 or around the front of 1. Your plug wires should be pretty well insulated as well.
ID:	109642   Click image for larger version
Old December 29th, 2014, 02:51 PM
I need to bu replacement guides as some are broken.
anyone know a good replacement?
Old December 29th, 2014, 03:21 PM
most parts stores have an assortment of those wire holders, genuine land rover are always best
Old January 3rd, 2015, 07:45 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Did you go back to oem wires first and work out the misfires before using other wires?
This happened to me with my d2. Switched to magnacor and my d2 started misfiring, even after using identical routing.
So I switched back to oem,problems gone. Bizarre,but stayed with oem.
Old January 3rd, 2015, 09:22 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
OEM is a must
No Mall crawler here
Old January 3rd, 2015, 09:33 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Originally Posted by rovertek View Post
OEM is a must
Do you have a source? I could not locate with the usual suspects.
Old January 3rd, 2015, 04:44 PM
I installed a set of Magnecors on my RRC years ago, that were bad. I am currently running "OEM" from Will. I have Magnecor on the 90 that probably need to be replaced.
Old January 3rd, 2015, 05:56 PM
They are cheap through the dealership last time I ordered a set. I want to say my cost was around $60. They come as a full set unlike DII wires that are individually packaged and cost around $250.
Old January 3rd, 2015, 07:18 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Thanks Jimmy… I'll check with LR Scarborough.
Old January 3rd, 2015, 07:39 PM
I have a complex mis-fire situation.
No spark while cranking.
If I pull the dizzy out, rest it on the plenum and spin it ... triggers then it clicks at each turn. If I put it back in the truck ... stops working. I even added an additional ground to the dizzy body in case it wasn't grounding but that doesn't appear to be the case.
Been scratching my head all day on this ... all the tests in the workshop manual are OK .... just no spark ....
Running out of ideas ...
Optimal Diesel Fuel Routing. rdavisinva Defender Technical Discussions 2 July 4th, 2013 03:07 PM
Speaker wire routing to front doors dave_lucas Defender Technical Discussions 7 December 29th, 2009 12:47 PM
Routing Wire Through Safari Cage WLDKGDM Defender Technical Discussions 3 May 23rd, 2008 07:46 PM
94 D90 wire harness & 94 A/C wire harness mdmuf Wanted 1 August 24th, 2007 09:33 AM
AUX Light wire routing steinhnj Misc. Chit-Chat 1 September 26th, 2006 10:18 PM
» Defender Registry
"Pete"
Overland90
#894
MyD90
Add your Defender
