Optima batteries - whats what? - Defender Source
Old August 16th, 2004, 02:28 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Got to replace my battery. I have already decided to go with a yellow top Optima SC 34DU 34/78 but...
once I found the optima web site, there are 5 types within the yellow top SC or spiral cell group, these are D31A, 31T, 6v, 34/78, & 34).
Rather than wait and slowly download each tech spec sheet (no comparitive chart available), anyone know the difference? I expect it is the CCA but with local SoCal prices spread from $109 to $198 there must be more to it .
Old August 16th, 2004, 04:20 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Paul,
Yes, there are a bunch of different yellow tops... I'd definitely go for one with a side mount & top mount, just in case you need to change it up down the road. It will be with you for a while.
I don't know 'exactly' which one you need but you may want to try EE... they have a nice writeup on the Optimas... and a nice writeup on setting up dual batteries.
http://www.expeditionexchange.com
just click on products... then... optima batteries... etc...
Hope this helps.
Nicholas Orros
Old August 16th, 2004, 06:01 PM
OK I read the PDFs they only take me 2 seconds to open at work
The D34 and the D34/78 is the same thing with the exception that the D34/78 has side posts. This type is the one that is most often used.
The D6V is a 6 volt battery it is 1/2 of a D34, DON'T use this battery as it is only 6 volts not 12 volts.
Then there are the D31A and D31T Both the same battery but the D31T has stainless steal studs, they are the same makeup as the others but they are a bit larger. I would not recommend the D31T because Stainless Steal is much more resistive then what is normally used in connectors, so if it was used with a winch the terminals on the battery would get nice and HOT.
Like I said all these the batteries are made the same, you will be fine with a D34 or a D34/78, but from what I am told if you use the side studs on the D34/78 do not bolt your winch to them as they are bars off of the terminal posts on the battery. That being said I have seen people hook there winch directly to those terminals and not have any problems, but I do not recommend it. The side posts are fine for everything else as you winch can and at times will draw over 400 amps.
Old August 16th, 2004, 06:05 PM
paulb's Avatar
paulb
Paul / Boultbee
I saw the EE site and was interested.
Ended up at Pepboys. Got a special $155.00 installed and I didn't have the 2.5 to 3.5 round trip to EE.
I also price shopped Autozone, Sears, 2 independants & Pepboys was $25 to $50 lower than everyone else. Of course that friendly curtious customer interface was lacking, but what the hey.
Old August 16th, 2004, 10:14 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I can tell you didn't shop Ebay. Nothing like a $50 yellow top. And P.S. unless you have a diesel, the red is better suited to what you need it for, but yellow looks cooler!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Dual Batteries on TDI / Optima Rugbier Defender Technical Discussions 24 November 17th, 2009 01:39 PM
Odyssey vs. Optima vs. Panther Battery Opinions? Maine 110 Defender Technical Discussions 16 October 20th, 2005 01:56 AM
Dual Optima question Joe P Defender Technical Discussions 2 August 31st, 2005 07:53 PM
Optima and standard D90 bracket artm Defender Technical Discussions 10 January 13th, 2004 04:24 PM
Batteries dead jorge Defender Technical Discussions 13 October 28th, 2003 03:28 PM
