Opinions about Boge unit - Defender Source
Old October 28th, 2010, 02:45 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
I don't have one - but after seeing the squat I got with a load, thinking about adding one. I know they are prone to wear/failure - but when operational, seems worth while. Yes/no?
Don't really want to add stiffer rears as this doesn't really address the issue and harshens the ride when not loaded.
Anybody have an assembly the want to sell? (will also ask in WTB section)
thanks
Old October 28th, 2010, 03:17 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
You could probably snag one off an old RRC for cheap. You may have to modify it slightly, but the unit on my RRC looks like It could fit my Defender easy with little or no mod.
Old October 28th, 2010, 07:44 PM
I have the one from my RRC you are welcome to it for beer and shipping. Hijack off..
Old October 28th, 2010, 08:06 PM
orionpco
larry burns
1962 series 2a
i just gave a friend a "boge" set up off of a rrc and i believe he was using it on a defender next. as far as i can tell it should be able to bolt up on a defender and the crossmember on the 89 rrc is very similar to the defender cross member, except the lack of mounting holes. i almost sure i have the cross member around here still, let me know if you would like some pics.
Old October 29th, 2010, 01:32 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Whoa.... Jeff, Oakland next week?
If your not too busy call me.
Old October 29th, 2010, 12:46 PM
16kpsi's Avatar
16kpsi
Tony Lawson
thanks guys. E-mails and PM's sent
Larry - don't think I need the cross member. The 110 cross frame has the mount holes in it already, so it should be a straight bolt up on top and a replacement of the lower perch and good to go (except for the whole prone-to-leaking boge unit issue)
Old October 29th, 2010, 12:54 PM
ini88's Avatar
ini88
Daniel Marcello
Tony gets first dibs. But if any of you have them laying around your barns and want a 6 pack + shipping let me know as I wouldn't mind getting a working unit too. I think mine is blow on my RRC and want to try to see how it drives with a working boge in the back!
------ Follow up post added October 29th, 2010 01:06 PM ------
I also thought about doing this: http://www.landyonline.co.za/techtal...conversion.htm
Old October 29th, 2010, 07:37 PM
16kpsi's Avatar
16kpsi
Tony Lawson
Daniel - Jeff is getting me a unit, so if you want to do the beer and shipping deal with Phillip, go for it.
Old October 29th, 2010, 08:17 PM
LMK its sitting on the back porch waiting for a new home.
Boge Unit removal Doug Defender Technical Discussions 15 September 14th, 2005 01:35 AM
Help.... acess to flasher unit Defender50th Defender Technical Discussions 2 July 18th, 2005 04:57 PM
94' Defender 90 A/C unit RX6RCROL For Sale - Parts 6 March 19th, 2004 08:41 PM
A/C unit for '94 Defender jracenstein Wanted 0 March 18th, 2004 01:39 PM
opinions needed and a pic? januconn92 Defender Technical Discussions 3 November 27th, 2003 01:01 PM
