Opinions - Defender Source
Old August 13th, 2009, 02:37 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Opinions
Hi
I have a 97 w/130k. Original.
The thing is incredibly dry, no leaks at all. It has been using regular oil but I want to make the switch to synthetic. Just wanted some opinions on if I should at this point. I know there have been previous post (Ron) about making the switch. Just wondering?
Also,
How difficult is it to switch the serp belt in a 97, for someone w/ minimal tools & moderate skill.
Old August 13th, 2009, 02:38 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why switch? If it aint broke!
Old August 13th, 2009, 02:39 PM
Campbell's Avatar
Campbell
Rich Campbell
Just thinking it might prolong its life.
Old August 13th, 2009, 03:18 PM
Serp belt is not hard to do. For you, I would suggest getting the fan clutch tools. Me, I do it with channel locks and a long screw driver. You know my views on synthetic, but I will add that if you look into the fill hole for the oil and it looks fairly clean, switching is much less likely to cause issues than if it is gummed up.
Old August 13th, 2009, 03:29 PM
Campbell's Avatar
Campbell
Rich Campbell
So if it is gummed up synthetic should clean it up but may cause leaks? What if I did a change every 1000miles at first would that help avoid leaks?
Thanks for the advice.
Old August 13th, 2009, 04:02 PM
If it is gummed up, synthetic may cause leaks and may also cause sludge to be dislodged blocking oil passageways or even the pick up tube leading to other issues beyond leaks. My normal way it to switch to synthetic and change the filter at short intervals and continue to do so until the filter is no longer "heavy" (you will be able to tell). If it looks really gummed up, I would be tempted to let it idle with a quart of ATF mixed in with the old oil for ~10-15min (or more) while hot before I changed the oil to synthetic. While I would normally change the filter at 1000 miles in the case of a synthetic switch over, I would be tempted to change at 500 miles if it was gummed up. However, the early changes are only to remove the sludge and build up that accumulate in the filter, not help with leaks. Frankly, I think the leak thing is over blown, I would be much more concerned with sludge being dislodged and causing other issues. In my view, if all that is holding the oil in is sludge and low oil pressure, then you have issues that are beyond redress with any oil.
Slotted Radius Arm Bushings -- Opinions? LRNAD90 Defender Technical Discussions 7 June 19th, 2006 11:37 AM
Odyssey vs. Optima vs. Panther Battery Opinions? Maine 110 Defender Technical Discussions 16 October 20th, 2005 01:56 AM
Make shift hi-lift ARB mount - Opinions? Antonios Defender Technical Discussions 4 September 18th, 2005 11:08 PM
Only one catalytic converter??? opinions?? cbass Defender Technical Discussions 7 August 10th, 2005 10:30 PM
opinions needed and a pic? januconn92 Defender Technical Discussions 3 November 27th, 2003 01:01 PM
