opinion needed: repairing tub corners - Defender Source
Old February 26th, 2013, 03:31 PM
Hi there folks, as you know, I am currently in the middle of rebuilding my truck.
I am sending my tub and roof off to the ASCO on thursday to have them blasted to accelerate my rebuild.
The problem I have is what to do with the corners of my tub.
Description of the problem:
About 8-10" of both the left and rear corners of the tub (outer wing) are in various states of disrepair. There are wrinkles and bends which I believe cannot be fixed by bending/hammering.
As I see it, there are several options:
1. Buy completely new left and right side outer wings and completely replace these parts of the tub. I will not pursue this method due to the enormous cost, time, and the need to spot-weld the wings to the rest of the tub.
2. Cut out the affected areas and weld in new metal. This could be done but requires very precise cuts and very difficult butt-welds across at least 18-24" of thin sheet aluminum. I would need to find a way to bend replacement sheet metal.
3. Cut out the affected areas and rivet (cosmetically appealing) new metal on top of the affected areas. This seems like the quickest and most cost effective method.
I am planning to go with option 3, but I was wondering if anyone had suggestions, opinions, and/or other options to consider.
Old February 26th, 2013, 04:18 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Post up a picture or two of the areas in question.
Old February 26th, 2013, 04:20 PM
Get some new skins and PanelBond them to the tub. Dunny dun.
This is far less annoying than any other course of action. You need to carefully drill out the welds from the outside so as to preserve the flanges on the inside portions of the tub. When it's all glued together you won't see any evidence that it has been repaired. It is a better way to attach as it is stronger than the original spot welds.
Old February 26th, 2013, 04:46 PM
will post some pics up tonight, thanks
Old February 26th, 2013, 04:57 PM
replacemnt panels aren't expensive and modern adhesives are as strong as spotwelds.
Old February 26th, 2013, 05:27 PM
are you guys sure that replacement panels are not expensive? Where is the best place to buy both a left and a right side?
Old February 27th, 2013, 08:29 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Another thought is that if you plan to offroad it, does it need to be strait? Or will strait-enough do?
-Jeff
That's big IF! We all assume that Kang's truck will never see dirt again!
Old February 27th, 2013, 08:32 AM
Hu
Old February 27th, 2013, 08:45 AM
Not worth messing with replacing panels. A little heat, a little hammer and dolly work, and leave it at that. Part of the history of the vehicle. You'll never get all the kinks out of all the stuff on the truck and besides you have a bunch of galvy shmatz on there, so clearly a smooth finish is not high on your list. Live with it. After it is painted and you have the capping on you won't even be bothered by it.
Old February 27th, 2013, 09:27 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Ed, call Josh Rowe at 703-342-7094. For ~ $250 you those panels will look new.
Old February 27th, 2013, 09:35 AM
Even a cheapo harbor freight body hammer and dolly will give you pretty good results. You work in the reverse of the damage. Start at the end of the wrinkle and work towards the start of it. Work high to low. That is, if the wrinkle pushed the panel in, you use the hammer on the inside of the panel to push the "high" spot outward. keep the dolly under the hammer as an "anvil". As you do this the metal will flatten, but due to the fact that the wrinkle has stretched the metal, you need to "shrink" it so that the panel won't be warped.
Use the toothed side of the body hammer and the dolly. I would recommend that you perform this on the non showing side of the panel, as it will chew up the surface quite a lot. I use a little bit of pull on the hammer strike when I do this, working the edges toward the crease. Don't hit it hard, use lots of gentle taps. It will eventually work itself pretty flat.
If you find you must do some additional shrinking work on the side that shows, you can always sand it down after and use some filler to bring the surface back smooth.
You can get other hammer and dolly shapes beyond the basic ones for specific problems, but you are OK for now
Old February 27th, 2013, 09:37 AM
Thanks guys.
Bill I have the HF hammer/dolly kit and it has been very useful on the rest of the build. I will give it a try on the tub corners.
Old February 27th, 2013, 09:40 AM
I can't believe you are even worried about those! I have some damaged door skins as well as roof tops and mangled sills that you could use for practice if you feel you need it, bit I say give it a shot with the hammer and dolly and move on.
Originally Posted by pendy
I'm here for the D's
Old February 27th, 2013, 09:52 AM
down_shift's Avatar
down_shift
Russell
The aluminum is too soft and thin for that. Tap on polypropylene sticks (about 1" dia) with various sized dull points and the dolly on the backside.
Old February 27th, 2013, 09:57 AM
Thanks Russ, will give that a try
95 ST-price opinion needed LandWorks For Sale - Vehicles 28 June 18th, 2010 10:04 AM
B Pillar to tub diagonals needed CDeWan Wanted 1 April 11th, 2010 06:46 PM
?? tub anchor point - needed?? paulb Defender Technical Discussions 3 June 23rd, 2005 01:02 PM
D-90 Rear Tub Needed ember Wanted 12 March 10th, 2005 05:08 PM
tub width on a '94 D90 is tapered "natural"? paulb Defender Technical Discussions 3 August 18th, 2004 07:07 PM
