Opinion: A frame ball joint - Defender Source
Old December 6th, 2011, 03:50 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I need to do my ball A-frame ball joint again.
Anyone have direct experience with the x-eng adjustable joint?
http://lucky8llc.com/Products.aspx?ProductID=7058
Otherwise I'm going genuine.
thanks!
Old December 6th, 2011, 03:57 PM
Why do you say "again"? What happened to the first one? These should last a long time... Are you lifted? Do you have non-stock travel?
The joint X-eng sells has been around for a long time and they are good if you have a lot of extra travel and they can be tightened up to remove slack.
Old December 6th, 2011, 04:06 PM
D90user's Avatar
D90user
steve
Its been 5 years and lots of bad roads, so not too bad.
Not really lifted... OME 754's but it is a camper so it is likely close to stock height +1-2in.
It has been loose for quite sometime and I like the idea of tightening. I'm not concerned with travel, just service life... I hate changing these.
Can you grease these when you tighten them?
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
A-Arm Ball Joint Replacement RyanS Defender Technical Discussions 5 June 11th, 2004 11:32 AM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
