One swivel kit, 90 and 110? - Page 2 - Defender Source
Old September 29th, 2016, 12:42 PM
Originally Posted by GuamPilot View Post
I don't have antiskid so the non-ABS DA3165 should work?
Mike & Carrie
Sorry, the 3165 is the later one, so not the right choice. 3163 or 3164. It depends on what swivel housing was used. The whole CV setup is different with the RRC design. It could be a whole mix and match setup. Who knows what parts you will need.
Old September 29th, 2016, 01:04 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Thank you! Trevor's page is a great resource on this question.
Mike & Carrie
Originally Posted by Naplm00 View Post
Yes you can remove the top pivot pin and see if you have a pin or a bushing without disassembing the rest of the hub. Just keep it clean and make sure to put back all the shims
Even easier just check this page from Trevor it has pics of the four types of pins. Early bushing style, early bearing, late bearing, abs
RovahFarm for all your new Land Rover Parts and Accessories
------ Follow up post added September 30th, 2016 03:05 AM ------
Is there a part number to be found on the swivel housing?
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
110, 90, kit
Swivel replacement - single or dual plates for swivel oil seal? TheOneTen Defender Technical Discussions 9 July 11th, 2016 06:23 PM
Swivel Ball Reseal Kit The Dro For Sale - Parts 4 April 3rd, 2013 10:25 AM
Swivel gaiter kit $50 TS888 For Sale - Parts 7 June 8th, 2011 09:44 AM
94 D90 swivel - oil or one shot from factory??? advnirvana Defender Technical Discussions 6 October 6th, 2009 11:46 AM
swivel balls what to do when pitted and why are 110 swivels so expensive draaronr Defender Technical Discussions 3 August 29th, 2004 07:35 PM
