One shot grease swivels - Defender Source
Old June 8th, 2006, 06:34 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
I changed all the lubes today, tranny, transfer, diffs, engine, and started on the swivels. This the first time I used the one shot grease for the swivels, I usally use 75/90. The grease was the biggest pain in the %^&*$, as it wouldn't go down easy at all even with a pump. The stuff kept coming out of the fill hole as soon as I pumped it. (yes I drained the swivel well). Any tricks you guys can suggest?
Old June 8th, 2006, 06:56 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Turn the wheel you are working on to full lock outward, leave the swivel drain plug out until you have filled it...the grease wont flow out but it will vent the air.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 8th, 2006, 08:17 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I put my grease in a pan of hot water before I used it to make it flow better.
Old June 8th, 2006, 08:26 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Ok, so turn full lock out, and leave the drain plug off, and warm up grease.. I will try it tomorrow. Thanks!
Old June 9th, 2006, 10:33 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Used your tips and it worked like a charm. Now if only my brain would work as well..with simple physics..
Old July 20th, 2010, 12:23 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm bringing back this thread to ask how often you should load new grease inside the swivel balls ?
I did it yesterday for the first time, one tube in each, didn't drain nothing before.
- Charles Eames
Old July 20th, 2010, 05:12 PM
Chaucer
Will
93 110 | 97 90
Interested also. Another (stupid) question: where does the old grease come out when you are putting in new? Does it come out the drain or does it come out the fill hole while you fill?
Old July 20th, 2010, 05:17 PM
bjf's Avatar
bjf
barry f
94 ST #395
Typically if you are doing this you are replacing the oil that was in the system. Open drain at bottom and it pours out. Fill with grease on top. SOmetimes using jack stands and turning wheels back and worth makes it move down quicker to get the whole tube in.
Old July 21st, 2010, 05:00 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Later hubs don't have a drain hole.... yup, pure British engineering that is!!!
you have to strip the hub to get the old grease out.....crazy!
Old July 21st, 2010, 09:26 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Use oil
Keith
Big, Red and ... aaa Red..
Old July 21st, 2010, 09:50 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I like to put the one shot in with new CVs, goes in easiest if the tie rod/drag link are disconnected and the wheel is turned to full lock.
Old July 21st, 2010, 01:31 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
That's correct and that's the reason i didn't drain.
- Charles Eames
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Long Shot - Trade e320 wagon for D90 uzj100 For Sale - Vehicles 2 November 22nd, 2005 03:07 PM
110 Military Swivels, balls, CV's, complete outer Buckon37s For Sale - Parts 20 November 3rd, 2004 12:14 PM
swivel balls what to do when pitted and why are 110 swivels so expensive draaronr Defender Technical Discussions 3 August 29th, 2004 07:35 PM
OEM Subwoffer box shot Neo Defender Technical Discussions 6 October 16th, 2003 10:08 PM
