One shot grease packets cv and housing? - Defender Source
Old May 28th, 2015, 10:52 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Kind of a simple question but I'm curious if there is enough grease in a "one shot" sachet to pre-lube the cv joint and still have enough left over to fill the rest of the swivel housing? Or should I be using cv grease first on the joint then dumping the whole one shot into the housing after assembly?
Finally is the one shot good for the stub axle roller bearing as well?
This is on a TD5 axle.
Old May 28th, 2015, 11:15 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I use bearing grease on all of the wheel bearings.
-Jeff
On the cv as well? Are you running EP90 in the housing or one shot?
Old May 29th, 2015, 12:29 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I like the idea of grease, until I consider water ingress & the job it would be to clean it all out & replace with fresh grease.
Old May 29th, 2015, 07:25 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
It's already been cleaned out which wasn't the cleanest job.... The axle is getting new ball joints and they are the new style Teflon ones with the inner seal, so I will be using the one shot.
I just was trying to determine if there was enough quantity to do everything with the sachet.
I think I will lube up the dry cv with cv grease then fire the "one shot" in the housing.
Old May 30th, 2015, 06:23 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Just give the CV a quick douse with 'One Shot' and then fill the swivel with the balance, the sachet is designed to fill/lube the CV and housing.
FWIW it's just a basic NLGI 00 consistency Li grease with 3%MoS2, nothing trick.
Old May 31st, 2015, 06:29 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
I'm with Tdi Rick on this one.
Just in case you're unaware,turn each wheel full lock at each fill to enable the grease to enter faster and with out overflowing.
All the best
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
Old May 31st, 2015, 01:10 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Thanks everyone. It's all rebuilt and filled. Used some cv grease when re-assembling the joint and one shot in the rest.
Oh and yes filled it at full lock.
Old May 31st, 2015, 04:35 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Job done!!!
ac
1997 D-90 rear axle housing and 83' 110 front axle housing Tyler Wirken For Sale - Parts 0 January 3rd, 2012 06:31 PM
One shot grease swivels thewap Defender Technical Discussions 11 July 21st, 2010 01:31 PM
94 D90 swivel - oil or one shot from factory??? advnirvana Defender Technical Discussions 6 October 6th, 2009 11:46 AM
Grease or Heavy Duty oil in CV Housing TND90 Defender Technical Discussions 7 June 19th, 2008 04:14 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
