One of my headlights is dimming. ??? - Defender Source
Old February 26th, 2012, 06:10 PM
Mpower619
Ricardo Gomez
1997 D90
So Ive noticed that my right front headlight is dim when on as well as my turn signals on that same side dont work. I did notice that if my headlight is turned off my turn signals will work perfectly. The problem with the turn signal is when I turn the lights on and my right front dims. Any ideas as what might be the problem? I checked the connections and they all seem in good working condition. All help is appreciated. Thanks
Rick
Old February 26th, 2012, 07:25 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
Sounds like you have either a bad ground, or a bad ground wire. I'd start looking at the ground and if it look good, try to ohm out the headlight ground wire (which will probably require a jumper to reach both ends) and see if you have high resistance.
ht, lights
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
My headlights are not working woldd90 Defender Technical Discussions 13 December 2nd, 2005 10:49 AM
2 Defender headlights Disco_Stu For Sale - Parts 5 September 28th, 2005 11:59 AM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
