One more for the clutch threadfest... - Defender Source
Old March 20th, 2010, 03:29 PM
Talk to me Goose's Avatar
Talk to me Goose
Mke Bishop
1995 D90ST #2199
So, time to end my lurking around the forum and put up a post -- in desperation, however
One morning I fired up the D and found I couldn't get in in gear.
I could start it in gear, but my friction point was about 1/4" off the floor!
Ok, I thought, slave cylinder first - Nope.
Ok, must be MC - Nope, still the same...arg!
I've now bled the bejesus out of it; the pedal feels more firm than ever.
I put a brick on the pedal last night to see if the pressure bleeds off - no.
Pumping the pedal doesn't help at all - its exactly the same as before I started.
So... I'm thinking flex line????
I know it's recommended to change all - Slave, MC, and Flex,
but the hose looks ok... no leaks, no obvious blisters when the pedal is depressed.
Can these fail without showing any issues externally?
I'm concrened that it might be something internal - collapsed throw out bearing or something?
Weird that it would happen overnight...
Any thoughts? Should I just keep bleeding?
Old March 20th, 2010, 04:02 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Any leaking any where that you can see. Maybe clutch fork going bad? See this towards the bottom:
http://forums.lr4x4.com/index.php?sh...=1&#entry52005
Someone with more experience will chime in I'm sure.
MUDSUX
Old March 20th, 2010, 08:28 PM
Talk to me Goose
Mke Bishop
1995 D90ST #2199
Hmm, that does seem possible I guess....
No creaking as he described, but I suppose if the ball hasn't quite punched through the fork, just partway....
What a royal PITA!
Old March 20th, 2010, 08:59 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
YES sounds like that is whats happened
Old March 20th, 2010, 09:04 PM
Talk to me Goose
Mke Bishop
1995 D90ST #2199
Well, that's good news I guess...
Getting at that release lever is not my idea of good times.
I'll keep my fingers crossed and wait for that flex line from RN.
Old March 20th, 2010, 09:28 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yes, the flex line can be deteriorated internally without showing any external issues.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
bleed, clutch, flex, master, slave
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
» Defender Registry
MALL QUEEN
MECA58
KT
rkinsk
Add your Defender
