One locker or two? - Defender Source
Old February 6th, 2004, 04:23 PM
scoloco's Avatar
scoloco
'94 D90 ST
One locker or two?
I'm looking to get some work done on my axles. Primarily change the gear ratios to 4.11, and while I'm in there probably fix up the 2pinion carrier.
Definitely going to put an ARB in the back. Question I have at this point is whether I should spring the extra $$ for one in the front also, or just leave it open?
If open, should I put the better 4pinion carrier in there or will the stock one suffice?
I'm interested in feedback from the New England folks, as that is where I plan to be in the not too distant future.
Comments?
tnx
-scott
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
Locker Question RickM Defender Technical Discussions 14 April 9th, 2006 12:41 PM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Locker - Front or Rear bd90 Defender Technical Discussions 6 January 14th, 2004 09:22 PM
ARB locker TwisteD90 Defender Technical Discussions 2 December 2nd, 2003 11:26 AM
» Defender Registry
GRNWOLF
GRNWOLF
westy04
marcd
Add your Defender
