One for the EXPERTS - Page 2 - Defender Source
Old June 19th, 2009, 04:05 PM
texmoto
david summers
99 Discovery II
Ok. Only way to test it is to drive around and wait and see if it dies when it gets hot.
Old June 19th, 2009, 04:18 PM
Originally Posted by ECR
That would be my guess if you have replaced the ign. module already.
Often overlooked part, but does exactly what you say is happening.
Wow, Mike agreed with me. I should buy stuff from him more often.
Near the MAF on the harness there is an area where it buldges that is wrapped in black electrical tape. When you undo the tape, you will see a (my LWB has two for some unknown reason) little black square thing about the size of a dime. Remove it and replace it. Not sure what it is called, but I was told it is some sort of resistor.
Old June 19th, 2009, 04:29 PM
texmoto
david summers
99 Discovery II
Uh, not to be difficult, but I think I'm going to need a part name or number, though the local independant rover shop is pretty friendly.
Old June 19th, 2009, 04:37 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Ahhhh, I know what piece you mean now. Not in the book unfortunately, so I can't provide a part number for it.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 19th, 2009, 06:04 PM
texmoto
david summers
99 Discovery II
Any idea where I can buy this thing. Mind you, I have yet to find it on mine.
Old June 19th, 2009, 07:00 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
hey, when you are right you are right.
I recall when we first found this issue years ago. If we ran the truck that had the hot stalling issue in the shop with the hood up, it cooled that thing just enough to not stall. If you rev'd the engine the fan would push just enough air across it to make it not stall. It took forever to figure out the first time. Run it on the road with the hood closed and then it would stall. Let it cool off, it starts and runs fine, for about 10 minutes until the heat builds.
Then we started messing about with a fan in the engine bay and it would stay running. Close the hood and trap the heat in and it would stall. Finally figured it out and duplicated it with a heat gun on the little resistor. It was a f8cker to find.
I can't tell you how many 90s come to us with "I just replaced everything in the ignition and it still stalls... you fix it". 2 minutes later... problem solved.
Email:
Old June 19th, 2009, 10:07 PM
texmoto
david summers
99 Discovery II
well, I still need to know where to buy one. mine was corroded. cleaned the spade connectors. . . . and the problem is still there. the part says Lucas RD 953066.
Old June 20th, 2009, 12:25 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Mike did you figure out how this little guy causes such a problem? I thought it was just a resistor in a small circuit providing the ECU engine speed info.I think it was around 7k ohms or something? Have you checked them to see if they're off or how they fail and why it messes with the idle?
Old June 20th, 2009, 12:04 PM
Hans's Avatar
Hans
Hans Haase
The ECU is only connected to the ignition system via that one wire, which provides the tach feed. Sure they may share a few other wires in the 12v supply, but that is the only SIGNAL passing between the two. This is also why the diagnostic display doesn't have any ignition related trouble codes.
If that resistor fails, at idle the ECU would sense no throttle input and no RPM. Add in when you're coasting to a stop, where the air cuts back naturally anyway, and you're adding O2 sensors reading lean too. The ECU would most likely think the engine has shut down, and thus cut off all fuel at that point. Since the fuel system technically didn't have anything else wrong, there would be no trouble code.
I am curious though if/how it could case a no-spark situation.
-Hans
I wonder if there is an off the shelf option here, if it's just a resistor. Anybody cut one open yet to confirm it?
My oil line fix
Old June 20th, 2009, 12:56 PM
texmoto
david summers
99 Discovery II
Does anyone have any idea where to get this freaking part? Or anything close to it?
Old June 20th, 2009, 01:36 PM
phoenix37's Avatar
phoenix37
john
http://www.britishv8.org/Articles/Rover-14CUX-EFI.htm
If you scroll down this should give you a little more info on what this resistor does it may help with your search. Maybe a radio shack or something like that will have a resistor that provides a similar amount of resistance. Are you still stuck away from home? Im in So cal and have an RRC sitting in the driveway I could canabalize at least until you get home.
Old June 20th, 2009, 01:42 PM
www.roverguy.com will have it used.
Old June 20th, 2009, 01:47 PM
texmoto
david summers
99 Discovery II
Thanks for the link. And thanks for the offer John, but I did make it home. But kind of you to offer. Radio Shack, Frys, ect have nothing like this kind of resistor (i.e. encased, heat resistant). Will try matching it at Car Quest on Monday (working 24 hrs. today).
Old June 20th, 2009, 01:52 PM
phoenix37's Avatar
phoenix37
john
No problem. I was worried you and your son were stuck at some truck stop trying to get home.
Old June 20th, 2009, 07:08 PM
cellulararrest
Chris Snyder
I'll have to keep this one in the back of my mind for the future.
Old June 20th, 2009, 10:22 PM
JRW's Avatar
JRW
94 D90 ST #1247
Originally Posted by phoenix37
Wow. This is a great resource on the 3.9 Rover engine bits.
Old June 21st, 2009, 12:57 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
I had a problem with stalling years ago in my 88 Range Rover Classic. It turned out to be the stepper motor at the back of the plenum. I took it out and cleaned it with solvent and it helped but it still lugged a bit. When I bought a new stepper motor it solved the problem. There is another name for the stepper motor but I cant think of it at the moment, oh wait it's the idle air bypass.
Here is a link to a guy that was having similar issues.
http://landroverforums.com/forum/showthread.php?t=2157
Old June 21st, 2009, 12:31 PM
Idle Air Control Valve is also another name for a stepper motor (only the brits call it a stepper motor).
Old June 21st, 2009, 12:52 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Thats it thanks. Seems there were lots of people having problems with these things a years back, dont seem to hear much issues with them anymore.
Old June 21st, 2009, 03:34 PM
I have a code 48 now if it makes you feel better. I need to reset my base idle as it is clearly been tampered with by a so called "expert" before I conclude it is the stepper (swapping and cleaning did not help it).
Ron
Question for the LR Color experts RiftRover Defender Technical Discussions 13 September 4th, 2009 12:38 PM
Winch...panel of experts Overland90 Defender Technical Discussions 23 January 30th, 2009 12:15 PM
Calling all experts! Emerson00 Defender Technical Discussions 11 May 16th, 2008 02:09 PM
Off Road Training weekend - Overland Experts in CT 3/29 & 3/30 pmd Trips, Trails and Events 2 March 19th, 2008 08:05 AM
Overland Experts - winter drving.... dmarchand Trips, Trails and Events 5 October 2nd, 2007 05:02 PM
