Onboard air setup help needed. - Defender Source
Old March 7th, 2014, 11:01 PM
RickM
Rick Mabus
95 D-90 ST
I need some idea help. I'm installing an arb Onboard air compressor under my passenger seat box. This will be used for airing up tires. I have it all set and working but I want to mount the air hose disconnect under the truck is I don't have to undo my interior to air up tires. I also want it mid truck so I'm not having to stretch to get to the rear tires. Finally I'm worried also about dirt and debris so having some type of cover would be awesome.
Soooo... What have you all done to accomplish similar setups?
Old March 7th, 2014, 11:19 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
You need to get ahold of Josh, Crash303. He has the most awesome on board air setup I have ever seen. ARB compressor under the seat, reserve air tank, and air hookups in each fender well.
A work of art, it is.
Old March 7th, 2014, 11:25 PM
navydevildoc
Neill Thornton
I think he needs to post a write up in the smaller projects section.
-Jeff
I agree. I guess I will have to see if he wants to take pictures...
Old March 8th, 2014, 01:54 PM
RickM
Rick Mabus
95 D-90 ST
Well I got it setup, but I really want to keep the head attachment clean. I'm thinking about some type of dry box.
Old March 8th, 2014, 02:02 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Yes, photos! I haven't installed mine yet.
Old March 9th, 2014, 11:18 AM
RickM
Rick Mabus
95 D-90 ST
Ok. I came up with a plan. It involves using the existing drain hole in the passenger cubby box, and a bait jar! I will get some pics up on this.
Old March 9th, 2014, 11:51 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The external hookup is a female quick disconnect, right? So get the male end and thread a cap onto it, keep it connected to the female hookup. Or try Parker for an actual quick disconnect plug. The plugs have a little loop on the end for a tether so it doesn't get lost.
Old March 9th, 2014, 12:23 PM
I had a setup like what you are describing in my previous Defender. Pump under the passenger seat, an illuminated switch on the dash to turn it on/off and an air tank stuffed under the hood with a quick disconnect for the air hose. It was cool looking but the ARB compressor was really tasked for anything other than airing up tires. I'm sure a bigger tank would have made it a bit better but then the ARB would be running for 10 minutes just to initially top off the tank.
I eventually purchased a Power Tank so I could continuously run air tools when needed and I still own it.
Old March 9th, 2014, 03:10 PM
RickM
Rick Mabus
95 D-90 ST
I am not running a tank, air lockers or tools on it. I have a Detroit setup on lockers, and you really don't want me around air tools. This is purely for my tires and also for our tubeless mtb tire setup when we are mountain biking. Anyway this is what I did.
Old March 9th, 2014, 10:27 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Hmmmmm, I was thinking of something like this:
http://www.amazon.com/Dixon-Valve-Co...F7Z0W2AZ52RY5N
With one of these threaded on the end:
http://www.amazon.com/dp/B004ZLBN1A/ref=biss_dp_t_asn
But yeah the tackle box works I guess...........
Old March 9th, 2014, 11:12 PM
RickM
Rick Mabus
95 D-90 ST
The bait box/jar is really there to keep the ARB issued female connector dry and clean. It had a really big screw on top, but a really shallow depth so it won't really hang down.
Complete F&R 4.10 ARB Air Locker Setup! - FOR SALE HeloBubba For Sale - Parts 41 January 17th, 2013 07:09 PM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Info needed on Arb air locker. rustydefender Defender Technical Discussions 5 January 9th, 2005 03:46 PM
