On-board shower - home built design - Defender Source
Old August 15th, 2008, 07:15 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I've been wanting an on-board hot water shower rig like some of my other club members but being the engineer type that I am I figured I could build a better system than any of the commercially available units I've seen. I'm about 90% done with my rig so I thought I'd share a progress report.
I was looking at some of the flat plate heat exchangers that some veggie oil burners are using in their diesels and thought that one of those would be a good starting point. The 16 plate unit I'm using is about 8" x 3" x 2" and I won it on ebay for around $80. These are supposed to be significantly more efficient than the coil in a tube type heat exchanger that are more commonly used. This also drove me to use a shower head with a manifold and mixing valves in case it gets the water too hot.
There's a great spot under the hood behind the right shock tower and just in front of the heater box where this plate exchanger can mount but I did not see a real good place to mount the pump for the system. I'm also concerned that submerging the pump in mud holes and rivers may not do it a lot of good so I decided to build the pump into a Pelican 1400 case with quick disconnects for the hoses and a waterproof power port for the 12v feed to the pump. This way it can be kept on the roof rack or inside the truck until it's needed.
I bought one of the Paha Que shower tents after reading good reviews for it on Expedition Portal and I'm working on designing a collapsable support stake for the shower head out of some aluminum extrusion I had lying around. For those really remote camping spots I can just clamp the shower to the front bumper and bathe al fresco. Like I said, really, really remote sites.....
Here's a few pics of the progress so far - I'll have it at MAR if anyone wants a closer look. I was originally trying to build it cheaper than the kit setups but I'll probably wind up with about $400 in the whole setup as it's a bit over the top - as we know it's ALL about the accessories.....
ID:	14789   Click image for larger version
ID:	14791   Click image for larger version
ID:	14793   Click image for larger version
Old August 15th, 2008, 09:52 PM
Very, very nice... but mine is still much easier... :-)
Old August 16th, 2008, 05:08 PM
how does the flat plat type do for heat transfer in reality?
Old August 16th, 2008, 07:15 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I'll find out in a few days when all of the pieces are in place - I'm waiting on a couple of fittings I need to reroute the heater hoses through the exchanger.
using home heating oil in Tdi artm Defender Technical Discussions 17 October 19th, 2005 03:00 PM
Home made rear bumper! TwisteD90 Defender Technical Discussions 21 May 12th, 2005 09:27 PM
Home design 3 link system UKlandyandy Defender Technical Discussions 65 February 17th, 2005 09:09 PM
Rear Hinges - New are Alloy Treated and Different Design Kimos Defender Technical Discussions 3 December 5th, 2004 09:51 PM
induction system design and mods jaherring Defender Technical Discussions 3 September 10th, 2004 08:20 PM
