on board air - Defender Source
Old November 8th, 2006, 01:01 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
on board air
What are you guys using. Is a tank a good idea for refilling after airing down for wheeling, or is a compressor better. If the compressor is better, which one. I don't even know the tank is a possibility.
Old November 8th, 2006, 02:01 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Dennis,
I run a QuickAir 2 on my Disco. It's enough to pop a bead on a stock rim. I installed a Viair 5 gal tank but didn't like the performance of the compressor with the tank so I removed it.
I think Jimmy runs a Co2 tank.
Good luck.
John (working my butt off in Manchester today)
John C.
Old November 8th, 2006, 02:46 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by JohnC
Dennis,
Good luck.
I'm impressed that you can reset a bead with that! Do you know if it can run airtools? How much are they? Thanks
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 8th, 2006, 03:07 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I have a Quickair 2 and a CO2 tank. I now only use the Quickair for the ARB lockers. CO2 is much faster for tires and one can run air tools on the tank, Quickair wont do tools...
Old November 8th, 2006, 03:53 PM
sorry but had too
Old November 8th, 2006, 03:58 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
I have an Oasis HP1000. I'm running an open chuck right now. I plan on building slider/tanks but haven't got around to it yet....
It's probably overkill, but it will run a 1/2" impact wrench and fills tires in no time. Downside- probably weighs 50 lbs.
Old November 8th, 2006, 04:19 PM
JohnC
Honestly, the only air tool I've run on the compressor is an air grease gun, that's it.
I'm impressed it can pop a bead also, I've had the unit for over 5 years and have used it many times to pop beads on LR alloy rims. I purchased some BFG AT 285/75 from Jimmy a few years ago and installed them on a set of Tornado rims using the QA2.
I believe they are a couple a' hundred bucks these days, I paid around $125 for mine years ago.
John C.
Old November 8th, 2006, 04:28 PM
RickM
Rick Mabus
95 D-90 ST
CO2 Air loss
I am not running anything right now but I was wondering, I have run c02 on MTB tires for a long time and have noticed a significant drop in air pressure over time. Has anyone noticed this on truck tires with CO2?
Old November 8th, 2006, 05:11 PM
Engine driven. $25
Only downside is you spend too much time airing everybody else that has an electric compressor.
Old November 8th, 2006, 10:17 PM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
I've seen a tube buggy at a local off-road park with a nice air set-up, They bought an air compressor thats designed to run on those lowrider air ride trucks, 2 1/2 gallon tank, and all the hoses and fittings you needed to run locker/fill tires/run tools. It could fill up their buddies 35' faster than the other electric compressors i've seen. But a powertank will fill up a tire faster
Old November 8th, 2006, 11:38 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
This is an older post now, but they work really great. I suppose mine has been running about 4 years now. A bunch of friends wanted me to do it with serp belts, but I just had too many things to do, so I don't know if you can fit one with them.
Sorry--here is the post...
http://www.defendersource.com/forum/...light=york+air
Old November 9th, 2006, 09:45 AM
talley-ho
Jim Talley
1970 Series 11A
On Board Air
I use a 15-pound Power Tank - it's fast and I carry a scale to keep track of how much co2 is left in the bottle.
Old November 9th, 2006, 04:08 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
20lbs CO2 tank I get from a local shop.
Jimmy Buffett
Old November 9th, 2006, 04:20 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
10lb CO2 tank from airgas $70 for the bottle then $14 to swap over empty
3rd low and BOOT IT
Old November 9th, 2006, 04:44 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
What kind of regulator do I need. I went down to the gas shop in my area and the regulator was 200+.
Old November 9th, 2006, 05:58 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
i would go with the power tank regulator and buy the bottle from airgas (alot cheaper) not as fancy as power tank but does the job. i brought 2 bottles so i always have a full one
3rd low and BOOT IT
Old November 9th, 2006, 07:08 PM
flippedrover
Tyler
'94 D-90
I did what Jimmy did with the Power tank regulator. Hmm.. The shop down here in DC quoted me I think 200 for a tank and regulator.
Jimmy Buffett
Old November 9th, 2006, 07:52 PM
Powertank with a Harbor Freight compressor (Viair knockoff) for a back-up. C02 tanks kick but for running an impact wrench or a cutoff wheel on the trail.
Old November 9th, 2006, 08:45 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You can usually find the regulators on Ebay for pretty cheap.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 10th, 2006, 02:06 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
I have noticed a drop after parking the car overnight. At times about 10psi. Never drops while driving and is easily topped off. I think the convenience of the CO2 tank far out-ways the loss of pressure. It may also be that when I stop the air in the tires cools and pressure is reduced.
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
On Board Air Davis For Sale - Parts 4 April 24th, 2006 11:36 PM
CO2, ARB on board air! TwisteD90 For Sale - Parts 4 June 16th, 2004 11:43 PM
On board air compressor Davis Defender Technical Discussions 5 March 7th, 2004 08:28 PM
On Board Air javelinadave Misc. Chit-Chat 13 December 2nd, 2003 12:41 PM
